Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 09-26-2004, 08:18 AM   #1
Exclamation 23 T S1 Glory Team Luna is too hot
I just bought 23T Superstock Team Luna S1. I tried this motor for 8 minutes run, but as a resut I feel it was too hot (cannot touch by finger). I drive TC3 with esc GT7 and final gear ratio is 6 (spur 72 and pinion 30).
Any idea why it is too hot?
imam is offline   Reply With Quote
Old 09-26-2004, 08:21 AM   #2
JDXray's Avatar
Send a message via AIM to JDXray
well it could be from wrong gearing, but it also could be the 8 minute run. You have to let the motor cool before each run.
Also check if your armautre is burnt or not, you said you couldnt touch it with a finger, sounds like it was fryed.
Jon
JDXray is offline   Reply With Quote
Old 09-26-2004, 09:21 AM   #3
Post 23 T S1 Glory Team Luna is too hot
Jon
I checked the armature is not burned/fried out (includes wires). Is it a matter of to low final ratio that caused hot. What would be the best final ratio for 23T?
Old 09-26-2004, 07:26 PM   #4
JDM_DOHC_SiR's Avatar
Default Re: 23 T S1 Glory Team Luna is too hot
It's somewhat normal for these motors to get quite a bit warmer than your standard 27t motor for one...8mins.... and also I belive that the S1 is the RPM version..which does get a bit hotter due to the fack that it's up in the high RMP most of the time.. the SII or Torque version is a much better motor than the Rpm based one
-Dave
JDM_DOHC_SiR is offline   Reply With Quote
Old 09-26-2004, 09:16 PM   #5
lee82gx's Avatar
23T stock is usually untouchable after 8 mins
we have geared these things at 5.5 and below although they generally don't last that many runs, they still work.
For practice runs i'd say use bearings and if possible a V2 endbell
lee82gx is offline   Reply With Quote
Old 09-26-2004, 09:19 PM   #6
tornado's Avatar
You use the V2 endbell on the 23T ?
Bryan
tornado is offline   Reply With Quote
Old 09-26-2004, 11:17 PM   #7
Post
I used standard endbell (stand up brush). I replaced bushing with bearing already.
Imam
Old 09-27-2004, 01:03 AM   #8
lee82gx's Avatar
Bryan
yes.most brushed motors can have a v2 endbell
Old 09-27-2004, 01:35 AM   #9
tornado's Avatar
Wala Wala ! Where did you get the endbell kit ?
Bryan
Old 09-27-2004, 01:39 AM   #10
lee82gx's Avatar
it's not an endbell kit.
just plucked it off a v2 motor.
but i think HPC is already selling the V2 endbells.
Old 09-27-2004, 02:02 AM   #11
tornado's Avatar
Really?!! gotta check them out !
Bryan
Forum Jump
1/14 Scale Old School Glory! dubluv Micro and Mini Scales 0 06-29-2007 04:54 PM
Team Luna 10t Mod Hand Wound Slotrc R/C Items: For Sale/Trade 2 06-06-2005 10:40 AM
23T Superstock Team Luna S1 is hot imam Singapore R/C Racers 5 09-28-2004 05:25 PM
Team Luna 9double Ti based RandyB R/C Items: For Sale/Trade 3 07-08-2004 06:55 PM
Need Info: Team Luna Motors Alvin Singapore R/C Racers 6 04-03-2002 04:57 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
