Old 10-01-2004, 10:45 AM   #16
Charlie O's Avatar
Originally posted by johnnywhopper
my servo wire was laying against the shaft one time, and i didn't notice it untill it had worn through the shaft. definately wasn't bound, and definately alot less friction than a rock, but it wore through anyway.
The servo wire would wear through before the dirve shaft, you must have gotten something else in there and it just came out before you saw it, and just assumed it was the servo wire.
Charlie O is offline   Reply With Quote
Old 10-01-2004, 10:47 AM   #17
it does seem unlikely but strange things do happen.
I had a battery wire smooth a spur gear down in my robitronic to literally a perfect smooth circle but the wire didn't have any damage.
Andy M is offline   Reply With Quote
Old 10-01-2004, 11:33 AM   #18
edseb's Avatar
This is a similar problem that many have had with the Yokomo SD. The composite twists and sometimes breaks. I broke one on my SD, and I know TC3 owners have had the same problem. In mod its just too much stress.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Belt Drive vs shaft drive vic88my Nitro On-Road 16 11-10-2007 07:26 AM
shaft drive vs. belt drive plz help pH1L Rookie Zone 1 06-07-2007 04:32 AM
Belt Drive versus Shaft Drive SUNA Nitro On-Road 20 03-28-2006 08:04 PM
Belt drive versus shaft drive...pros and cons of each? AttackDonut Rookie Zone 21 01-02-2005 04:23 PM
Belt drive or Shaft Drive tc3wood Electric On-Road 4 12-03-2004 06:57 AM
SEO by vBSEO 3.5.0
