Does this exist?
Does this exist?
I'd like to find an onroad type car, rubber tires, but direct drive in the rear. Where the axle is through the spur gear, the pinion on motor is direct on the spur with no other gears or reductions.
I'm thinking like the older Parma good times kits are set up but they are foam tires. I run mostly on pavement and it rips foams apart.
Thanks,
Ron
Thanks,
Ron
F1 cars....some F1 cars out there run on rubbers and have direct drive like pan cars.
There's a Corally car.....
that has 3 drive options with one of them being what your looking for. It's called the Assassin I think. Go to www.teamcorally.com and have a look.
These guys sell cheaper rubber capped foams for pan cars like the Associated Rc10-L# Touring.
http://www.tm-rc-racingcomponents.com/index.htm
The hotter the weather, the harder the compound. Here is a direct link to the cap tire page
http://www.tm-rc-racingcomponents.co...me1Source1.htm
the tamiya f103lm cums with rubbers in fact im having sum seriose truble finding foams for it
check this webpage www.d-drivesports.com
Ask Mr Furuya about his wheels if you have an old tamiya chassis or a Corally CCT and you can use your rubber tires on this car, he offers an awesome quality, you will see!
i cant read japanise
i use altavista translator..., and then click on touring
Hey, the Duratrax F1 car is on sale at towerhobbies for like 99 bucks... and doesn't Bolink make a direct drive 2wd touring car with rubber tires?
Later
Jake
Later
Jake
its was at 50!!!! on tower 4 a while
