Like Tree2Likes
Old 07-06-2016, 03:26 PM   #331
bornox's Avatar
Trader Rating: 26 (100%+)
Originally Posted by robk View Post
If you mean the Tamiya "TCS" tire, imprinted with the TCS logo on the sidewall, yes they do use the foam tire wheel.
sorry, i mean the tamiya part# 54198
bornox is offline   Reply With Quote
Old 07-11-2016, 02:02 AM   #332
Hello Guys,
Have you also issues with XR's on asphalt?
After 2 runs, it's like tires are done. No more rear traction and soooooo many steering...
If I change the car setup, it's still the same...
Regards,
Nicolas.
Team Awesomatix / Team Roche / Team Corally / Wild Turbo Fan
nicoo2k4 is offline   Reply With Quote
Old 07-11-2016, 02:41 AM   #333
Regional Moderator
disaster999's Avatar
What are you break in process? What tire sauce are you using? What are the track temps?
Typically you need to run 3-4 packs of battery through the tires to fully break them in. Sauce them fully and let it soak for at least 15 mins to 30 mins. I generally find these tires decent front end grip, but not so much that rear is sliding around.
disaster999 is offline   Reply With Quote
Old 07-11-2016, 03:11 AM   #334
Hudy additive, 15 minutes rear, 5 minutes front.
@ETS Luxembourg, track was hot, then cold, but still the same.
@EC Hudy Arena, it was pretty hot, around 32 in air.
These tires was good on carpet, but on asphalt, it really pain is ass.
Old 07-11-2016, 04:04 AM   #335
The same here the first run massive under steering second run ok and after the third run you cant throw them in the bin not even good enough for practice.
From the rumour's I've heard Ride changed the compound from last years XR
to this year XR to the soft way.
Even some people where running alu chassis @ ETS Luxembourg.
To get that steering away.
toroloco is offline   Reply With Quote
Old 07-11-2016, 04:17 AM   #336
Regional Moderator
Weird, I run the XR on preped asphalt and get pretty good grip out of the tires. I get good enough traction I dont even bother saucing them or doing any tire prep.
Im not sure what type of formula or version of the XR I have but I have these for about half a year now, so I guess its the "old" formula. I get a lot more traction compared to Pit Shimizu 573/571 combo.
Old 04-28-2017, 11:35 AM   #337
G-rem's Avatar
Hi there,
can you please give me advice for new tires?
I'll be running on unprepped asphalt low grip track (air temp from less than 20 to 30), and I don't know what to choose:
- new Ride GR (front and rear)
- Shimizu 571/572
- Shimizu 571/575
- Shimizu 573/572
- Shimizu 573/575
Thanks a lot for your help!
Regards,
G-rem
G-rem is offline   Reply With Quote
Old 06-13-2017, 10:17 AM   #338
Trader Rating: 4 (83%+)
I run shimizu 571 572 with exotek +3mm wheels on gray carpet with aluminum ring to save the front rims !!
and today I received a set of the new F1 gravity tire ! ( ride GR ) i will test next weekend
Boostinswifty38 likes this.
Xray T4 2017
Yokomo BD7 2015 Spice FWD
VBC FF17 FWD
VBC FXM F-1
Roche evo 2017 F-1
Quinny45 is offline   Reply With Quote
Old 06-13-2017, 04:45 PM   #339
JayL's Avatar
Originally Posted by G-rem View Post
Hi there,
- Shimizu 571/572
- Shimizu 571/575
- Shimizu 573/572
- Shimizu 573/575
Regards,
G-rem
571 /575
maybe even 574 front
G-rem likes this.
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 06-13-2017, 05:20 PM   #340
What are most running on black carpet since the 571/572 combo is too grippy and tippy
~Xray~RCAmerica~Motiv~Gravity RC~ORCA~
Swift Racing Services, LLC.
JDC Motorsports
Boostinswifty38 is offline   Reply With Quote
Old 06-13-2017, 07:25 PM   #341
Regional Moderator
I need this!!!!
Old 06-14-2017, 04:57 AM   #342
idbdoug's Avatar
Trader Rating: 33 (100%+)
Supposedly new gravity F1 tires will stop this problem on black carpet. Our track hobby shop has them on order so I'm going to try them
idbdoug
www.serpentamerica.com
www.r1wurks.com
www.falconsekido.com
idbdoug is online now   Reply With Quote
Old 08-01-2017, 11:31 AM   #343
Trader Rating: 24 (100%+)
Hi,
I'm new to F1. Can you guys advice me which compounds and rims is good for CRC Black?
Thank you,
Mugen MGT7 Nitro MRX6, XRay T4 17' X12 16', VBC FF 17', Hot Bodies D815
willman is offline   Reply With Quote
Old 08-01-2017, 11:53 AM   #344
CA on the front sidewall works wonders for traction rolling on black carpet.
altitudelow is offline   Reply With Quote
Old 08-01-2017, 12:05 PM   #345
I'm ran the Gravity tires for the first time at our last point series race. So much better than the Shimizu combos for me. Our parking lot track is prepped, but at most, we start low and build up to medium traction during the day. I was chasing X1 chassis setups for a while until last weekend on the Gravity tires. Not once did I spinout, and I was able to drive harder and more aggressively than ever. We run 21.5 F1. My lap times were on par with my USGT T4.
I did full sauce for 15 min and wiped before Q1. Did some warm ups but it seemed to take a while to get some grip. For Q2, I didn't prep and did about 5-6 warmup fast laps and they were dialed. Q3 I sauced only the rears, wiped right away and then just used the rag to wipe the fronts. That seemed to be the ticket. And I didn't bother saucing for the Main and took 3rd.
On Shimizu's I could do donuts for days. The Gravity's seem to have a harder front that keeps the car from doing donuts from a stand still. It's got a nice controlled push.
I'm using 2.0 silver springs in front and gold in the rear with 200k in the tubes.
forFREEDOM is offline   Reply With Quote
