Like Tree2Likes
Old 06-19-2016, 09:16 PM   #316
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Its normal for the tires to do that, even on asphalt. It usually takes a ton of runs before it gets to that point.
Dan is offline   Reply With Quote
Old 06-19-2016, 09:40 PM   #317
Regional Moderator
disaster999's Avatar
yeah I run on asphalt, these are the 572 rears.
Theres still plenty of meat left on them but this ring of death is cutting the tire life short.
disaster999 is offline   Reply With Quote
Old 06-20-2016, 10:23 AM   #318
JayL's Avatar
Even if they didn't groove and you tested against a new set the new set would be Faster.
Tires are not just as fast until you wear out the rubber to the belt.
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 06-20-2016, 02:40 PM   #319
Acid_CZ's Avatar
Send a message via ICQ to Acid_CZ
If you dont have problem with rear grip, dont aply tire gripper to that part. I usually wet centre up to 3mm off the edges.
"If you no longer go for a gap that exists, you're no longer a racing driver"
Ayrton Senna
Acid_CZ is offline   Reply With Quote
Old 06-20-2016, 02:54 PM   #320
Trader Rating: 28 (100%+)
I was gonna say.....New kicks are always faster. Now as far as drop off after the 1st couple runs at maximum performance, they are usually a tenth or 2 slower but will stay in this range for quite some time in the tires life. I personally have never run until that happens.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 06-21-2016, 05:00 PM   #321
F N CUDA's Avatar
Trader Rating: 30 (100%+)
I race F1 with some success on "seasoned" tires on asphalt and carpet.
New tires always make my F1 cars feel edgy and a little unpredictable compared to used ones. A few runs and they're good to go for a long time for me.
Now with touring cars, completely different story. If I could afford it, I would only run new meats. Not even close when worn a little.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 06-21-2016, 07:10 PM   #322
Great. You also run 25.5 on tiny tracks
Team I'm Over It
Old 06-27-2016, 10:29 AM   #323
spring71's Avatar
Smile
RIDE XR Compound tires are available now.
http://www.tqrcracing.com/shop/produ...t.asp?s_sort=3
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 06-27-2016, 05:40 PM   #324
F N CUDA's Avatar
It's been all 21.5 til just recently, and mostly on asphalt.
Tamiya track rates as tiny? I didn't think so but that is where I've used most of my F1 tires.
Only a couple times have I tried freshy tires in a big race there and never won doing that.
It's always been on used skins that I've had my best races, easier to drive and no noticeable drop off in laptimes, actually quite the opposite.
My fastest laps have been on scrubs.
Craig Hammon
Old 06-27-2016, 05:50 PM   #325
aracefan's Avatar
Trader Rating: 38 (100%+)
FYI, Thanks.
Thank You for posting this!! Just ordered a set, they're always sold out.
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is offline   Reply With Quote
Old 06-27-2016, 06:09 PM   #326
Just busting your chops. I talked with Mike Rydwell a little and you guys run a lot different tire setup then we do up north. Hey whatever works. I would love to only run "seasoned" tires.Easy on the wallet.
Team I'm Over It
Old 06-27-2016, 07:13 PM   #327
F N CUDA's Avatar
Saul Goodman
We've been through everything available and a few of us have settled on our favs for sure. Some are still hunting, tires, foams etc. but for the most part I'm pretty sure only a couple combos are at the front of the field here.
"ExoMike" included.
Craig Hammon
Old 06-27-2016, 07:57 PM   #328
MikeR's Avatar
Trader Rating: 15 (100%+)
Smile
Racenut and Cuda are both right. What it means is the best tire is very dependent on the track that you run at. I took a trip up north and the scuffed and ballistic set of 72/kit tires that are great at Socal were horrendous up north. Wasted a day changing setups trying to make them work. Bought a new set of 71/72 from the guy pitted next to me and bingo- I was battling with the fast guys (Racenut) for podium... 71/72 combo on an asphalt track- crazy!
fyi- I tried the Ride XR's as well... undriveable at that track.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 07-06-2016, 08:52 AM   #329
bornox's Avatar
Trader Rating: 26 (100%+)
hi! i dont know if this is the right thread, but i want to ask if i can use the foam wheels on tamiya rubber tires? thanks!
bornox is offline   Reply With Quote
Old 07-06-2016, 01:06 PM   #330
robk's Avatar
Trader Rating: 22 (100%+)
If you mean the Tamiya "TCS" tire, imprinted with the TCS logo on the sidewall, yes they do use the foam tire wheel.
