Ask Steve "The Evicerator" Weiss
#6961
spx
Steve,
what do you think a good starting point would be using 7.5 and 6.5 novak ballistic using a spx and the punch set at 1 at iic race.
#6963
The Evicerator
I would guess a 7.5 FDR for the 6.5 and probably a 6.5 for the 7.5!
Hey J type! Thanks man!
Looking forward to it for sure!
#6964
hey steve,
Do you know if
5908 sintered rotor will fit the balistic 5.5 motor?
I noticed the 5909 one says it does....
As My brand new never even been soldered to motor from tower has a bent shaft, i noticed it when setting gear mesh for the first time it goes tight loose prety badly, even with other new pinions also. and i really dont want to send it back as im in aus and it will take ages.
Do you know if
#6966
The Evicerator
hey steve,
Do you know if
Do you know if
The 5908 and 5909 rotors will fit the ballistic motors just fine!
If you have experience with an SS Pro 10.5 motor the gearing should be close to what you will end up gearing with the ballistic as they run very similar!
#6969
novak on rctvlive
Hi Steve,
I saw rctvlives recent show with smart boost for one cell racing. My question is do we NEED to run one of those? What will happen if you dont? I think I will get one but was just wondering.
#6970
The Evicerator
If you have an extra motor I'd try that out to try to see if it is the motor or the ESC. If the motor does not run, then you know the problem is somewhere in the ESC and should probably be sent in for service!
Most modern RC car electronics are designed to run off of a 6.0 V input... when you don't run with that input sometimes things still "work", but they do not work as intended... IE, things can go bad, the performance can suffer, or strange problems can occur. When running a booster circuit, you are supplying 6V to the ESC, the receiver, and the servo just as they were designed to use.
#6971
Havoc 1s speedo
Steve, has the new Havoc 1s speedo shipped from Novak to all the dist.?
I looked at Tower and it says they have it on order and its due in mid-Oct. Is the the true delivery for the Havoc 1s for everyone? If I order one through OCRC how long would I have to wait?
#6972
The Evicerator
Assuming OCRC puts their order in to their distributor right away it should only take a week or two after we ship to the distributors for the hobby shops to get them into stock!
#6974
The Evicerator
