Ask Steve "The Evicerator" Weiss >
Old 12-09-2008, 08:13 PM
  #6616
Toh WL's Avatar
Steve, just check with you. For a Novak Velocity 4.5T motor. What are the indicator which would require sintered rotor replacement.
I opened up the motor & see that the rotor is black. Eventually I can see the surface is thining. Performance wise still can run.
Toh WL is offline
Old 12-09-2008, 08:31 PM
  #6617
The Evicerator
If it's a black rotor that is 14 mm in diameter it is one of the original bonded rotors... I would definately recommend replacing the rotor with a sintered rotor!
Steve Weiss is offline
Old 12-11-2008, 03:52 PM
  #6618
Trader Rating: 49 (95%+)
Ok, got the spread spek GTB installed with the 3.5, but what do I need to do to get it as punchy as it was with the LRP esc? Does the motor timing need to be changed or ? It's just as fast but lacks the "rip" I used to have coming off of the low end and midrange acceleration.
loopedout is offline
Old 12-11-2008, 04:12 PM
  #6619
The Evicerator
What are you geared?
What kind of batteries are you using?
I assume this is in a TC?
Old 12-11-2008, 04:32 PM
  #6620
Trader Rating: 208 (100%+)
Steve what is the rotor diameter on the Novak motors? I know the drift are 13mm.
Never ind I found 12.3mm
Any plans on a 12.5mm rotor?
dodgeguy is offline
Old 12-12-2008, 07:48 AM
  #6621
The Evicerator
Anything is possible, but at the moment there are no plans to make a 12.5 mm rotor.
Old 12-12-2008, 08:14 AM
  #6622
Toh WL's Avatar
dodgeguy, I am using Novak GTB & also LRP TC Spec. The noticable difference is TC Spec is only forward ESC. The TC you can go as low 3 turns. However you can set the ADPC from Value 1 to Value 8. Higher value will give a real hell of a punch during acceleration & make the car fly. Hence you notice extraordinary performance compare with GTB which already factory optimized.
The drawback is your motor, ESC & battery can get very much hotter. So the setup, wiring, battery selection need to be taken into serious consideration.
Toh WL is offline
Old 12-12-2008, 08:19 AM
  #6623
Toh WL's Avatar
opps.. i am ref to loopedout not dodgeguy. typo mistake
Toh WL is offline
Old 12-12-2008, 10:09 AM
  #6624
Steve,
I want to run a Mongoose, a 17.5, 2s lipo in my gen x-10. This will be my first season running indoor carpet and I thought this would be a very tame setup and a good one to learn with. Oh and cheaper.
What 17.5 would I buy if I went this route and do you think its even worth trying?
Also could I get a 13.5 540 sized motor to run with this speed controller?
nitrosteve is offline
Old 12-12-2008, 10:15 AM
  #6625
The Evicerator
the mongoose will probably work for you...but you're going to get better performance out of a 4 cell GTB or even a Havoc ESC and I would recommend looking into one of those ESCs instead.
AS far as which 17.5 to get, I recommend our 17.5 pro. It comes with the sintered rotor, ribbed endbells, and ready to race!
Originally Posted by nitrosteve
Steve,
Old 12-12-2008, 10:23 AM
  #6626
Trader Rating: 16 (94%+)
Steve - When is Novak going to change the wiring harness to a removable style, and when will Novak be updating their SS motor line overall?
Novak is pretty much the last major brushless player to still include attached sensor harnesses.
kn7671 is offline
Old 12-12-2008, 10:39 AM
  #6627
The Evicerator
KN,
All I can "really" say is that we're always working on new products over here and that's a very popular request...
We have alot of stuff planned for next year!
Old 12-13-2008, 11:48 AM
  #6628
Tc5 lto. Novak 3.5. Ib shv4600. 10.9 fdr
Old 12-13-2008, 08:44 PM
  #6629
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
Steve, how does the min. drive settings in the GTB work?
All i can say about it is when i set the value higher i gain initial power but the top end power suffers and vice-versa.
|JayFlores|2 is offline
Old 12-15-2008, 04:09 AM
  #6630
Default brushless
Hi Steve,
Is it possible for a motor to perform differently if ran several times a day eg 5 times
I run a 13.5 pro and lipos
For no apparent reason in any one of the 5 rounds my car is slower in a straight line.Basically unpredictable. I run the same gear ratio in all 5 races.
Using rubber tyres. (lets assume my car is well maintained and doesnt have any binding or poorly prepared issues)
Also how can I tell if my lipo charger is peaking correctly
Should my lipo pack always peak at 8.4v
I have seen my packs cut off at say 8.15v at times and I hit repeak then my charger may put few milliamps in then cutoffs after few seconds so its stating the fact that it assumes the pack has peaked correctly.
I do balance charge once a week night before I race
Your thoughts?
yeahyeah is offline
