Ask Steve "The Evicerator" Weiss
#5611
The Evicerator
#5612
The Evicerator
Dan,
Brushless systems are generally more efficient than their brushed count-parts... I would expect you to get longer run times with brushless than with brushed given the same battery pack.
#5614
The Evicerator
Dennis,
No, you should be able to just drop either the 12.3 or the 13.0 mm rotor into your motor without needing any extra parts. All of the Velociti motors shipped with the large front bearing which the sintered rotors require.
#5615
Hey Mark,
I spoke with one of the engineers about your problem yesterday and he seemed pretty surprised that the cyclone wouldn't take a one touch setup from your HRS... he said there shouldn't be anything preventing it from taking the setup and that he specifically remembers testing the one touch setup function with very fast frame rates ...
If we have some time we will try to dig up a cyclone around here and see what we can find out about it!
Perhaps there is something different about HRS with FASST, compared with the previous HRS?
#5616
The Evicerator
Yes, we will have to take a look at it and see what's going on... although he said that there shouldn't be a difference between the one touch programming on the GT7, GTX, and GTB.
#5618
ok Steve so am I on the right track that a BL motor is basically a sinusoidally wound three phase motor driven by three sinewaves input to the phase A,B, and C inputs, shifting them 120 deg from each other? the sinewaves generated by PWM?, a DC supply would be too inefficient IMO. then using an electromagnetic resolver to sense the rotors angular position?>
#5619
The Evicerator
#5620
Steve,
If I have 145000 xmas lights at an average of .5watts each that runs for 8 hours a day for 45 days. Plus a xmas tree with 1050 lights that average .5watt each that are on for 5-6 hours a day for 45 days. Plus a nativity scene that averages 300watts for 8 hours for 45 days.
How much will that effect my electric bill in Canadian Dollars?
Thanks in advance....
-Shookie <><
OH DENNIS...Better get ready.....Shookie is starting to feel better...SUCKA...
-Shookie <><
#5621
The Evicerator
Shookie,
If you run all those lights all that time you might not be able to buy that Xbox 360 for Christmas
#5622
Microsoft already controls 90% of life...If I give in to them with the 360 I might loose my mind not to mention my wife...LOL
#5623
Steve, 3 questions for you:
1) If cutting through 2" aluminum plate with a sawzall, what would be a good TPI to start with?
2) How long would it take to cut through 14' of 2" aluminum plate?
3) How loud of a bang does a 400# chunk of aluminum make when it falls 6' and lands on a flooring surface made of 1" thick steel?
#5625
The Evicerator
