Ask Steve "The Evicerator" Weiss
#5116
#5117
Two Steve Weiss'? Sounds like a trademark infringement case. Could be in court for years. Maybe you should consider settling for some $$$ and change your name.
#5118
steve i just look at novak web site and there is a new larger diameter 13mm sintered rotor, what effect this new sintered rotor provide?? Will it reduce the cogging effect ????
#5119
The Evicerator
The new 13.0 mm rotor increases "magnet cog"... but you should not really ever see the "stutter cog" problem.
This new rotor gives better accelleration, braking, and performance with heating.
#5120
one of the parts where the screw goes in on my GTB broke and so now the screw just spins. I would glue the piece back on but it appears to be missing. is there any way (without sending in the whole GTB) I could get a new GTB lower case part or am I stuck with three screws?
#5122
The Evicerator
Smjoe,
Just contact customer service at 949 833 8873 or [email protected] and inform them of your problem and your address and we can get you a case and screw sent out to you no problem!
#5123
hey whats up scuba you plan on racin any time soon? later jason
#5124
Do any of you guys know if there was a weight break given to the 5 cell cars at this past Reedy Race of Champs or at the On-Road Nats? If so what was the weight? Thanks
Brant
Brant
#5126
#5127
The Evicerator
Total race weight with 5 cells is 1450 grams
#5129
#5130
The Evicerator
Yep!
