Old 01-15-2013, 06:34 AM   #811
LonnyJ1950's Avatar
Originally Posted by Radio Active View Post
Interesting, so it's basically doing the job of side springs for side-to-side resistance and tweak adjustments. I guess there is more slop in that arrangement than a side-spring set-up would have, otherwise I could see it working on a modern pivot ball car.
One of my favourite pan car set-ups was the one used on the Tamiya F102 and Group C cars. It's similar to what you describe. T-bar connected to the chassis (essentially) but there is an o-ring instead of a washer in there. Tightening the screw that went through the T-bar and the o-ring would put more pressure on the o-ring and reduce side-to-side movement. I always enjoyed tuning my car with nothing more than a Phillip's head screw-driver in under 5 minutes.
If you build the sway bar properly, there is virtually no slop, and it is infinitely adjustable. It was difficult to fit under a lot of bodies, and would be worse today. I would much rather have a good sway bar than side springs.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 01-15-2013, 01:03 PM   #812
chris moore's Avatar
Trader Rating: 85 (99%+)
There might be enough room if you mounted the sway bar under the top plate about half way between the top and bottom plate. With todays inline configurations there might be enough room, I still have on of my old AE cars fitted with the a swaybar.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 01-15-2013, 02:56 PM   #813
LonnyJ1950's Avatar
Tim and I built swaybars for the 12L to stop it rolling so far it dragged. They worked very well. Because of the peculiarities of T-bar cars, we were able to substitute a bump stop set up that was much lighter and simpler. That wouldn't work on a link car. The hardest part of a swaybar is putting some sort of ear on the right side of the pod for the right pivot. The 2 pod pivots have to be symmetrical or the car will be tweaked. You could do it, but I'm too old and lazy to scratch build these days.
Lonny
Old 01-15-2013, 03:08 PM   #814
DesertRat's Avatar
I think the key to a successful lipo-link swaybar car would be to keep the swaybar narrow and small, like just looping in front of (or even in some way incorporating) the pod pivot, and maybe 1.5" wide, as opposed to old swaybar systems where the bar was the full width of the chassis.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 01-26-2013, 10:00 AM   #815
LonnyJ1950's Avatar
If you make it too narrow it will be too stiff. There is actually a rather small window for the proper stiffness. On the ones we made, .063 wire was too stiff, but .055 worked perfectly.
Lonny
Old 01-26-2013, 10:06 AM   #816
LonnyJ1950's Avatar
Originally Posted by THEBIGBULL View Post
I must have at least 10 or more old 235mm pan car bodies I've collected over the years, all uncut and unpainted. I would love to get extra's. I will have to contact him and get these back on the market. I will have to see what I have and make a list.
BE
TJ
Anything ever happen with this?
Lonny
Old 01-26-2013, 11:49 AM   #817
Thumbs up
I emailed Team Bluegrove about a week ago and my email just got bounced. I will try again today. I also have the Protoform Corvette and the 200mm Mulsanne which protoform has discontinued. Later!!!!
THEBIGBULL is offline   Reply With Quote
Old 01-26-2013, 12:11 PM   #818
corallyman's Avatar
Trader Rating: 97 (100%+)
Does TeamBluegroove offer a "real" replica associated TOJ for 1/12th and or 1/10th. They also should do the driver figures again. Back in the day, it used to be required to use a driver figure, and I did not like it. Now I want to add one to my 1/12ths. Kinda funny
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 01-26-2013, 01:02 PM   #819
You mean like this one?
TBG already does a few.
Or if you prefer an Osella in 1/12th and 1/10th, then Bob's your man.
terry.sc is offline   Reply With Quote
Old 01-26-2013, 01:02 PM   #820
I've seen the AE TOJ. Have not seen the heads for 12th scale
RoyU is offline   Reply With Quote
Old 02-06-2013, 06:33 PM   #821
Radio Active's Avatar
Was it common for people to try and convert their RC10 buggy into a 12th scale?
At least I assume that's what this was: http://www.ebay.com/itm/rc10-0117-vi...item5d395a5c7d
It looks like it's had a hard life. I'm tempted to buy it just to give it a home.
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 02-06-2013, 06:39 PM   #822
That looks like something scratch built. Home made fiberglass chassis, Parma rear pod, Bolink T-Plate. Nothing really vintage RC10 about that.
InspGadgt is online now   Reply With Quote
Old 02-06-2013, 06:40 PM   #823
Correction...that is the Sassy Chassis rear pod from a RC10LSS or RC12L...That's about the only part RC10ish about it.
Old 02-06-2013, 06:52 PM   #824
Ah thanks, the "For Vehicle Type: Buggy" bit lead me astray.
twitter: @dvcotton
Old 02-19-2013, 07:10 PM   #825
Ok, I have a technical question I think the Classic 12th community is best placed to answer.
The original Deltas had the shock basically level mounted from the chassis to the rear of the pod, like so:
Pretty much all of the later (and modern) cars have the shock mounted from the front of the pod to the centre of the chassis, sloping down to the centre of the chassis.
For example:
From what I've read increasing the slope of the shock increases mid-corner steering while reducing exit steering. This seems true from my own testing on track. I had the shock dead-level at one point and it was detrimental in that it would push through the mid-corner and then oversteer on exit.
The only modern car that has a shock layout anything like parallel with the chassis is the Speed Merchant Rev 7:
However, what I find curious is that the later Delta cars went the opposite way to all their competitors. They angled the shock the other way:
http://photos.hobbytalk.com/data/510/delta_chassis.jpg (damn anti hot-linking)
So, my quesiton is why did they do that? Is it just that the shock needs to be on an angle, and it doesn't matter if the gradient is positive or negative? Is it something curious with the rear mounted shock set-up? Or just that the older cars needed more exit steering?
And more broadly, what is the mechanism by which shock angle changes the steering characteristics in the corner?
twitter: @dvcotton
Sedan vs 1/12th scale budget Iceracer Electric On-Road 21 03-12-2007 07:06 AM
1/12th scale sedan bodies - where to get? Motor City Hami Electric On-Road 14 03-27-2006 10:05 AM
CRC T-Force 1/12th scale letitroll R/C Items: For Sale/Trade 9 11-28-2005 06:26 PM
2004 IFMAR ISTC & 1/12th On Road Worlds at Full Throttle Speedway AdrianM Electric On-Road 2162 12-29-2004 03:09 AM
