Old 01-12-2013, 08:55 AM   #796
CypressMidWest's Avatar
Originally Posted by avs View Post
the listing indicates TBG. the seller(teambluegroove) on ebay has several different bodies listed all from TBG, one with a sticker showing. apparently he is a specialist in vintage bodies.
Yeah, everything he does is a reproduction. He has several versions of the old Andy's GTP bodies.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 01-12-2013, 10:50 PM   #797
I was looking thru TBG bodies and I saw that they now have the AE GTP Jaguar which I believe to be the Group 44 Jag.
I have been looking for this body a while now.
RoyU is offline   Reply With Quote
Old 01-12-2013, 11:01 PM   #798
And he has the old AE Toyota! That was a cool body!
Old 01-12-2013, 11:05 PM   #799
I wish he would make the older 235 pan car bodies!
Old 01-13-2013, 05:13 AM   #800
To do that it's the same as all the other vintage on road bodies. Get a new, uncut original and send it to TBG. Once he has made the pattern he will send you back 3 repros from it as payment.
terry.sc is offline   Reply With Quote
Old 01-13-2013, 08:26 AM   #801
Giorgio's Avatar
Speaking about bodies...
I just found some old pics of my Parma Panther.
I remember them... and I was sure the body to be a Parma-Lancia LC1
Durign the years I found a Parma Lancia and plan was to make a repro of the real car....
But.... look at the picture. Is a Lancia Lc1.. but who make it??? Is way more real than the Parma one...
https://www.facebook.com/FenixRacing.it/
www.fenixracingshop.com
Giorgio is offline   Reply With Quote
Old 01-13-2013, 09:45 AM   #802
If I only had original, uncut bodies
Old 01-13-2013, 12:18 PM   #803
Thumbs up
I must have at least 10 or more old 235mm pan car bodies I've collected over the years, all uncut and unpainted. I would love to get extra's. I will have to contact him and get these back on the market. I will have to see what I have and make a list.
BE
TJ
THEBIGBULL is offline   Reply With Quote
Old 01-14-2013, 05:16 PM   #804
BE
TJ
Lucky guy
Old 01-14-2013, 06:39 PM   #805
Radio Active's Avatar
This is the second old pan car I've seen with a rear sway-bar. What was the purpose of the sway-bar? What did it do that the T-bar wasn't doing?
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 01-14-2013, 07:44 PM   #806
Not all t-plate cars had tweak screws so the t-bar would just pivot without a sway bar.
Old 01-14-2013, 07:51 PM   #807
azeroth's Avatar
Trader Rating: 20 (100%+)
T bar was on pivot balls and there wasn't side springs or tweak screws like in later designs some early t bar cars like delta had no pivot balls t bar was mounted solid to main chassis only seperated by washer from the main chassis plate to allow it to flex
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 01-14-2013, 08:59 PM   #808
Interesting, so it's basically doing the job of side springs for side-to-side resistance and tweak adjustments. I guess there is more slop in that arrangement than a side-spring set-up would have, otherwise I could see it working on a modern pivot ball car.
One of my favourite pan car set-ups was the one used on the Tamiya F102 and Group C cars. It's similar to what you describe. T-bar connected to the chassis (essentially) but there is an o-ring instead of a washer in there. Tightening the screw that went through the T-bar and the o-ring would put more pressure on the o-ring and reduce side-to-side movement. I always enjoyed tuning my car with nothing more than a Phillip's head screw-driver in under 5 minutes.
twitter: @dvcotton
Old 01-14-2013, 09:09 PM   #809
azeroth's Avatar
yep i agree way easier and faster to tune lol. was pick a tire and your gear and pray you went the distance
Old 01-14-2013, 10:05 PM   #810
Thumbs up
Lucky guy
No luck involved at all Roy. Pro Ten has always been favorite class. I have been watching Ebay for probably 8 years and every time an auction went for the right price they became mine. I also have 15 or more Pro Ten cars, Associated, Trinity, Corally, etc,etc. I will check into the TBG idea and if they can repop them you may well be able to get some as well. Between Indy, GTP, Can Am and Nascar I'm sure I have over 30 with wide and narrow editions.
BE
TJ
Sedan vs 1/12th scale budget Iceracer Electric On-Road 21 03-12-2007 07:06 AM
1/12th scale sedan bodies - where to get? Motor City Hami Electric On-Road 14 03-27-2006 10:05 AM
CRC T-Force 1/12th scale letitroll R/C Items: For Sale/Trade 9 11-28-2005 06:26 PM
2004 IFMAR ISTC & 1/12th On Road Worlds at Full Throttle Speedway AdrianM Electric On-Road 2162 12-29-2004 03:09 AM
