Old 04-08-2012, 08:43 PM   #691
Johnny Wishbone's Avatar
Originally Posted by LonnyJ1950 View Post
Actually, we ran the light ones like the one in the Parma package. To make it last just be sure you get all the way off the narrow bands with the wiper button at full throttle. We rigged a second wiper over the full throttle band to trap the moving wiper and maintain firm contact. It is surprising how little time you spend at part throttle, especially in stock. My friend Tim Neja actually reversed his and used the long end for brake and the short end for throttle to get quicker response.
Thats why the parma was popular because it had the high end bypass built into it, although we used the second wiper method more effectively. Most of the time the heat problem was caused by lack of good spring tension in the wiper arm itself, but we never ran any of the resisters with the turbo coolers.
As a side note, after looking at your car, I remembered that one of the "trick" items on that car was aluminum 4-40 screws on the top side of the motor pod.
Also I believe the copper tubed axle was made by TRC.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 04-08-2012, 10:06 PM   #692
TracySlatten's Avatar
Yes, the second wiper on top is what I'm planning on too. The packaged resistor pic shows the tab that was bent over for that option. That is the trick to getting them to work properly, good tension but still smooth and flat. The wiper button needs to be flattened, not the rounded shape it has on the contact patch of the resistor when they are new. You can also flat spot the back side of the wiper button so that when the button trails off the last band it does so all at once, not a tappering contact patch with stock round button.
Thanks again for the input guys, I'm sure I will have a question or two about what to do with the rear spring thing/rubbber hose/or what? Maybe a shock?
I'll shoot the pics of the throttle setup sometime later this week, quite a bit of work actually. Hopefully I get a few laps in before it smokes
T
Thanks to all the people helping with the Seatac Track Project.
TracySlatten is offline   Reply With Quote
Old 04-15-2012, 09:03 PM   #693
Default Project 12i #6
Getting a little father along now! I have added most of the radio components, added blue AE themed hardware, and roughed in the streering arrangement. The Futaba radio is an FP-T 2F AM 75Mhz, pure analog stuff here. The car side is Novak NES1A servos and a NER-2S receiver.
I had to change the wiring in the transmitter to reverse my steering servo thow to reverse throw. Novak servos are either "normal" or "reverse". I had 2 normal throw servos, so rather than change the servo wires around it was easier to change the radio. Now right is right. After that I centered the steering servo feedback pot and aligned the servo saver up to the radio trim centerline, done with the radio on and screw driver down the servo output shaft. Now center is center. The antenna mount is a stock 12L piece dyed black, yellow pushrod, and black rubber tip. I still have to add the trim pot for steering dual-rate adjustment to the radio.
T
Classic 1/12th-2012-04-15_19-42-27_382.jpg   Classic 1/12th-2012-04-15_19-39-06_885.jpg
Old 04-15-2012, 09:12 PM   #694
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Wow! Nice Futaba box wheel radio. That thing is mint. Where did you find that? Are you gonna run that radio using the throttle levers or are you gonna throw on a Parma pistol grip mod on it?
YR4Dude is offline   Reply With Quote
Old 04-16-2012, 08:38 PM   #695
I found the radio here in Seattle, new. I started racing with this radio without the parma mod (add slot car controller handle to the back) and I am comfortable to holding the radio as is. I have held other radios with the pistol grip mod and they felt front heavy with trigger offset like an airtronics now...I went to a Kraft (KO) pistols next and then airtronics, until now. I am going to give it a go without adding the mod, for now. The thottle servo is oppisite in that config too...pushing for throttle instead of pulling. (I think, as I remember)
I am searching now for a novak 21 spline disc... or arm to complete the throttle setup, I have the resistor support from the parma frame almost done, but no disc/arm for the throttle servo.
Old 04-28-2012, 01:52 AM   #696
V12
V12's Avatar
Got a Kyosho Impress R951 like this http://www.rc-car-museum.de/1_12_Mod...ess_r_951.html but without wheels.
Someone has an english version of the manual or know the part number for the wheel set?
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 04-28-2012, 07:57 AM   #697
bakaguyjean's Avatar
I have lots of wheels, drop me e-mail and we can work something out.
I have two of these and spent months trying to get it work. Horrible car.
Anyway here is the parts list and let me know if you need the manual for the carpet option.
Classic 1/12th-impress2.jpg
bakaguyjean is offline   Reply With Quote
Old 04-28-2012, 11:18 AM   #698
YR4Dude's Avatar
Default Kyosho R951
Got one also. Never built it. Just left it NIB. Maybe its a good thing I never built it.
Old 04-28-2012, 09:44 PM   #699
Default Project 12i #7
I recently sorted through some tires and matched up some rims. Contact cement and laquer thinner, mmmm. After that, true em up, and back onto the car; ride height is about 4mm.
Next, a before and after pic of the parma slot frame. I have a little shaping to do, but the resistor is ready to position soon. I made the barrel heat sink fit the resistor, then opened the parma mount holes up to match. After I come up with a servo arm I can locate everything.
With the sanyo 1200's and fresh tires, the chassis flex and suspension feels soft and smooth!
Classic 1/12th-2012-04-28_16-24-31_778.jpg   Classic 1/12th-2012-04-28_19-37-41_567.jpg   Classic 1/12th-2012-04-28_19-37-04_572.jpg
Old 05-14-2012, 01:44 PM   #700
Giorgio's Avatar
A new baby... I'm waiting for her in the next days....
Schumacher C-Car. Spec after 1986 Euros, from the front beam, should be 1987/88...
I never had this in the proper time (I've had Delta, Asso, Alpha...) so I'm not exactly "mad" for it. Thought was interesting to have it and maybe use it a trade for more interesting items....
I know some one here might be interested in....
https://www.facebook.com/FenixRacing.it/
www.fenixracingshop.com
Giorgio is offline   Reply With Quote
Old 05-15-2012, 07:14 PM   #701
Default trying to identify
This is an estate I acquired I am trying to identify the cars I also have some 1/12 bodys uncut clear.
Classic 1/12th-dsc08838.jpg   Classic 1/12th-dsc08836.jpg   Classic 1/12th-dsc08835.jpg   Classic 1/12th-dsc08832.jpg
dalolyn is offline   Reply With Quote
Old 05-15-2012, 07:31 PM   #702
First one looks like a Trinity Revolver 12 of some variation...not sure which
Old 05-15-2012, 07:31 PM   #703
Bob-Stormer's Avatar
dropped ya a pm.
www.stormerhobbies.com "Where the world shops for radio control."
www.facebook.com/stormerhobbies
www.twitter.com/stormerhobbies
looking for....vintage 1/10-1/12 pan, need Schumacher 1/12th cars and parts.
Bob-Stormer is offline   Reply With Quote
Old 05-15-2012, 08:32 PM   #704
LonnyJ1950's Avatar
Bob probably gave you the low down, but the one in the first picture is the original Trinity Revolver 12. Pic 2 looks like a 1/10TH Delta Super Villain. A rare car. Looks like you also have a Delta 1/12TH Super Spyder, also a rare car. In the last picture I see several Associated 12Es and several I can't identify.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 05-16-2012, 12:49 PM   #705
tazfam2's Avatar
Trader Rating: 40 (100%+)
does anyone know who and if they make a 1 cell saddle pack for a t plate 1/12 scale Thanks for the help
Xray x1 17 Xray t4 2017
T4 2017 tekno 48.3. Associated B6 B64
Leisure Hours Hobbies and Raceway
Fiercesolutions.com
Windy City RC raceway and hobby's
tazfam2 is offline   Reply With Quote
Sedan vs 1/12th scale budget Iceracer Electric On-Road 21 03-12-2007 07:06 AM
1/12th scale sedan bodies - where to get? Motor City Hami Electric On-Road 14 03-27-2006 10:05 AM
CRC T-Force 1/12th scale letitroll R/C Items: For Sale/Trade 9 11-28-2005 06:26 PM
2004 IFMAR ISTC & 1/12th On Road Worlds at Full Throttle Speedway AdrianM Electric On-Road 2162 12-29-2004 03:09 AM
