Touring Car carpet tires
What are the best carpet foam touring car tires? I use TRC right now, but I would like to try out other tires. Can someone recommend another brand and how they like them.
Thanks! |
you could try jaco's they are go carpet tires
Try some TRC Purple/Plaid or some Jacos Orange Pink/ Purple or DBL Pink Orange/ Dbl Pink work very well. Umm Jaco DBL Pink/ Dbl Purple work well too. Just gotta ask some local racers what they use.
Jon |
Why are touring foams so expensive and nitro so cheap.
Doug |
I dunno i wish they were cheaper. I got mine on sale for 17 :rolleyes: they were 23 :weird:
Originally posted by JDXray I dunno i wish they were cheaper. I got mine on sale for 17 :rolleyes: they were 23 :weird: |
Hey thanks guys for the great info. But did anyone use off brands with success? Other than jaco and trc. The must be other tires we can use with the same quality. Imports? :)
Originally posted by powerpark Hey thanks guys for the great info. But did anyone use off brands with success? Other than jaco and trc. The must be other tires we can use with the same quality. Imports? :) |
Alot depends on what class motor you are running and the condition of the track.
At my track the hot tires for stock are Jaco Plaid (purple/orange) in the front and purple in the rear. For modified it's Jaco Pink/orange in the front and double pink in the rear. If you do not like Jaco, you can run the TRC equilivant. If you want to be competitive on an indoor carpet track, don't waste your money on any other branf other than Jaco or TRC. |
Jaco
Here at our track as well is Jaco Orange/Purple front or double purple front and purple rear. 28 mm wide. Don't use the 24mm wide.
Gonna also try some cyan and magenta TRC which are 26mm wide. Also, need to make sure you keep the foam trued and keep measuring them to get the proper rollout. If not you could have different size tires and will effect your handling. |
BSR makes a very good foam tire as well. It's the same rubber and wheel you will find on the Jaco, but the bonding process is different. It's less likely for the rubber to peel back off of the rim.
I don't know anything about the tires but they seem to be cheap
www.rctexas.com I found them from the add at the top of this page. |
I think those are outdoor tires.
