Old 09-22-2004, 01:48 PM   #16
Im not too familiar with pro4 terminology but you need to fiddle around with the droop screws unitl the droop is even on both sides. The bottom line is that a droop gauge is key, since you want to set it after the suspension is assembled.
As for the actual settings, you don't necessarily have to set the front to half the droop of the rear. Experiment and see what you like best when it comes to handling. It's a simple way to start making changes to your car's handling. So, I wouldn't focus too much on the specific droop setting, as you will definitely fiddle around with it.
TPJ International
071crazy is offline   Reply With Quote
Old 09-23-2004, 01:23 AM   #17
Cole Trickle's Avatar
Droop setting is very important !
1) Get that droop gauge as soon as possible.
2) Ensure all 4 shocks have the same length, when fully extended.
3) Set the downtravel at 2 mm all around.
4) Try the car.
5) Try reducing the droop at front to for example 1 mm.
6) Try the car.
This way you have a good starting piont. And you probably also have a good feeling of how droop settings impact the handling.
Two kind of droop settings, which is really bad: No droop and uneven droop.
By the way, I still race with a Pro2, nice car.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Droop settings fruitland04 Electric On-Road 15 11-17-2007 05:15 PM
droop settings on tc3 Lord_Darkhelmet Electric On-Road 5 02-05-2006 08:32 PM
setting droop on droop blocks mrgsr Nitro On-Road 3 01-08-2006 06:01 PM
droop settings Team-RTR Australian Racing 13 10-21-2004 03:36 AM
droop settings Alvin Electric On-Road 5 10-02-2001 04:08 PM
SEO by vBSEO 3.5.0
