Old 04-27-2011, 08:03 AM   #1
Onetrade's Avatar
Trader Rating: 14 (100%+)
Default Over-Discharged Lipo, Can it be Revived?
I have a 4S 2100mah lipo that I believe was over-discharged. 3 cells seem to be good and one seems to be bad. When I last hooked up my Venom Pro Charger it charged it charged the battery and then I got an error. When I tried to re charge it I got 3 cells at 4.06 and 1 cell at 1.57 and it raised to over 2.0 and then i got the error again.
Can anything be done?
Battery doesn't really look puffed and if it is maybe very slightly. It is a softpack.
Battery is for a starter box.
Has balancing tap and deans.
-Just Drive It
Onetrade is offline   Reply With Quote
Old 04-27-2011, 08:15 AM   #2
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
You can place it on a ni-mh charge WHILE YOU WATCH IT CHARGE and bring it up to say 11-12vs then stop it, swap over to lipo mode and charge.
I STRONGLY suggest putting this in a lipo sack and even possibly charging it outside away from other stuff.
IF the cell goes full bad it will puff and cause damage to the pack and anything around it.
Something about winning attracts losers with opinions......
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, B-fast, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 04-27-2011, 09:11 AM   #3
If one cell is at 1.57 volts, it's done!!! If it was only a little below 3 volts, you might be able to save it, but this sounds like you discharged it too far and never charged it back up. That cell has an internal short, and trying to charge it may result in flames.
You're using a 4 cell lipo battery for a starter box??? Just use a 12 volt gel cell. They're cheaper, stronger, and won't go boom!
jiml is offline   Reply With Quote
Old 04-27-2011, 09:44 AM   #4
rc18junky's Avatar
the best thing to do if a lipo goes bad is to get rid of it. 2100 turnigy or skylipos are under 15 bucks just get a new and forget that headache
Savage25 XL7-RC18t 9200K-Recoil 8000K-TC4 5700K-TL01-Raven ST-GTP2 XL7-Slash 4200K-MicroDT brushless and other crappy broken ones
rc18junky is offline   Reply With Quote
Old 04-27-2011, 01:14 PM   #5
padailey's Avatar
I've done what Randy suggested but have never had a cell that low before. Good Luck!
Tamiya TRF417X (Lion's Automotive GTR)
Tamiya TRF416X
Tamiya F104W MP6/4 converted to F104X1 (Renault R30)
padailey is offline   Reply With Quote
SEO by vBSEO 3.5.0
