Old 09-18-2004, 03:39 PM   #1
Diode dilemma......(a quick question)....
Ok I've stuffed up and cut the wires of the schottky for my new esc to short and I need to know if the spare I found (from an older esc) will do or if I should get the same as the one I stuffed?
The one I cut to short is rated 5 amps and 40 volts and the spare I found is rated at 60 volts other specs are slightly different also(see included picture).
The esc is a Nosram Dominator which I will be using in 540 stock class with 1500 mah packs so I hope the diode I have will do because getting another the same as the original will not be easy locally.
The one I cut is the 504 on the chart, the spare I found is the 506.
Thanks in advance.
Mabuchi540 is offline   Reply With Quote
Old 09-18-2004, 03:42 PM   #2
Oops here's the pic.
Quick Question...about XXX-T R40Victim Electric Off-Road 7 05-14-2008 07:54 AM
Quick question VenturaDC Electric Off-Road 0 11-14-2007 04:10 PM
diode & super capacitor question nikkiesteban Electric On-Road 2 01-30-2007 10:56 PM
question about scoti diode EngTat Electric On-Road 24 05-12-2005 06:41 PM
Schottky Diode Placement Question mike_Webb Electric On-Road 17 03-27-2002 01:20 PM
SEO by vBSEO 3.5.0
