Old 04-23-2011, 05:35 AM   #1
UrabusDenis's Avatar
Default Foam & rubber maintenance
Hello guys !
I started this thread to share experiences with storing rubber tyres and foams . What do you do to your tires to keep them in good shape ? I clean my rubbers with brake cleaner after using them , while some say WD should be used while storing your tires ? With foams , I just "clean" them with air compressor ...
Your thoughts ?
BTW : What is the use of those sidewall stickers on 1:10 foams and do you stick them ?
UrabusDenis is offline   Reply With Quote
Old 04-23-2011, 11:34 AM   #2
Trader Rating: 43 (94%+)
On my tamiya f1 ruber tires i use 30wt motor oil let it soak for 10-15min then wipe the off. and clean with mean green.
tcb22185 is online now   Reply With Quote
Old 04-23-2011, 11:41 AM   #3
Redwings's Avatar
I like to use simple green or a type of degreqser on the rubber tires. I have even tried goo gone and then wipped it off and let them sit. the tires were sticking to my fingers after that. Now for foam tires, I likw to use a semi hard brissle brush just to get the crap off, other wise nothing else. hope this helps.
Redwings is offline   Reply With Quote
SEO by vBSEO 3.5.0
