Like Tree27Likes
Old 02-27-2017, 01:26 PM   #766
The fantom 5000 mah lipos did hold better voltage than the TP3300.... I have lightened up my tc4 enough to give the 7500 graphenes a run...I'll probably end up with a 1400gram car, but I am hoping the graphenes and zero degree toe will make a difference....
bertrandsv87 is offline   Reply With Quote
Old 02-27-2017, 01:30 PM   #767
Metalsoft's Avatar
Trader Rating: 69 (100%+)
TB03 still taking names in USGT.
TB03 is one of the best old school cars there is.
For me it's a toss up between the TB03 and the TA04.
Tamiya TB03 USGT - Custom Carbon fiber Chassis - Magoo Racing Inc....
Metalsoft is offline   Reply With Quote
Old 02-27-2017, 08:41 PM   #768
DesertRat's Avatar
It's not a bad chassis at all. Tamiya always seems to have their suspension geometry pretty well sorted out, then they shoot themselves in the foot and make the kit chassis plate an injection molded bathtub!
Good to hear you're having fun and success.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 02-27-2017, 08:51 PM   #769
gigaplex's Avatar
They also released an EVO version that used dual deck carbon fibre, for those that required it. Also, tub chassis can work. The TC3 didn't have a problem with it back in the day.
gigaplex is offline   Reply With Quote
Old 02-27-2017, 09:48 PM   #770
DesertRat's Avatar
Yeah, but TC3's got to run foamies. You can run 40 pound per inch springs with those.
There is an inherent problem with the chassis being too wide at some point.
Old 02-27-2017, 11:02 PM   #771
gigaplex's Avatar
While true, the TC3 setup sheets for team drivers running rubber tyres typically showed silver and blue springs (15-17 lb?) with the wide tub.
Old 02-27-2017, 11:36 PM   #772
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
I remember old SoCal track setups for TC3 rubber tire/asphalt using Gold font and Silver rear. Some even Red front Gold rear. Or Gold front and rear.
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 02-28-2017, 06:40 AM   #773
RiderZ's Avatar
Default !!!
Here's my TA04 with new motor and shocks installed.And a new Protoform Cadillac body.
Old TC Cars - Still Racing Competitively-img_1635.jpg   Old TC Cars - Still Racing Competitively-img_1638.jpg
RiderZ is offline   Reply With Quote
Old 02-28-2017, 01:25 PM   #774
tamiya wrc's Avatar
Hello! ...I have a question regarding to Tamiya TL01 chassis...I also recently upgrade my TL01 chassis with Hobbyking X car brushless system...basically 60A ESC with sensored combo motor 4000kV 8.5T, for battery I chose Turnigy nano-tech 2S2P lipo 4200mAh...I also replace plastic bushing with ball bearings...solve some steering issues with setup arms...but still I am wonder is this chassis even capable to manage so powerfull motors? ...I think that I also need to replace drive shafts and also 19T pinion gear...with some metal version...what kind of ESC setup do you use...for example...motor timing and initial acceleration...probably the lowest possible? ...thanks.
tamiya wrc is offline   Reply With Quote
Old 02-28-2017, 01:29 PM   #775
tamiya wrc's Avatar
Originally Posted by rccartips View Post
Video was back in 2010, no shorty yet. TA04 c-hub and knuckle on plastic TL01 arms for some caster.
Here is a 2016 video, with shorty
+ YouTube Video
Old 02-28-2017, 01:34 PM   #776
DesertRat's Avatar
Stop typing with a stutter. It makes it hard to figure out what your question is.
The quick answer is no, the Tamiya TL01 is not a good candidate for the power your 8.5 turn motor will make. It will probably hold together for a while though. As opposed to getting metal gears and other parts I would upgrade your chassis to something more durable and modern, such as a 3Racing Sakura 0 for $100.
Old 02-28-2017, 01:37 PM   #777
In the video was Tamiya 12T sensorless motor. If 8.5T yes you might need the metal shaft and start with a smaller pinion
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 03-01-2017, 09:44 AM   #778
Send a message via AIM to GuyIsDamGood
Originally Posted by ShadowAu View Post
While they look the same I believe they Pro 4 axles are metric and the TC4 axles are imperial. Its not a huge difference but enough they aren't interchangeable
Thanks for the info ShadowAu. I had a feeling the Pro 4 and TC4 Axles were different (the treaded - metric part makes the difference).
GuyIsDamGood is offline   Reply With Quote
Old 03-01-2017, 01:25 PM   #779
gigaplex's Avatar
It's not the threaded part that makes the difference, you could just use a different nut. The bearing size requirements are what matters.
Old 03-01-2017, 08:43 PM   #780
Hello! ...I have a question regarding to Tamiya TL01 chassis...I also recently upgrade my TL01 chassis with Hobbyking X car brushless system...basically 60A ESC with sensored combo motor 4000kV 8.5T, .
I ran my TL with a 9T motor, afriend ran his with a 5T
The powertrain can cope, although get a good pinion . You will need to replace one of the internal plastic gears every now & then, through wear, not breakage.. However , no so sure the chassis will cope, speed wise.
It will be OK untill the 1st corner
The TL01 has some brittle plastic parts, so will break easily on crashes, compared to say a bulletproof TT01
1101 is offline   Reply With Quote
WCIC '06/'07 grabber Canadian R/C Scene 984 07-05-2007 10:55 PM
Tags
414, kawada, sv-10, tamiya, tc3
