Like Tree37Likes
Old 03-31-2016, 03:00 PM   #436
My TL01 racing weight is 1322grams (lightweight chassis, mazda6, shorty pack). FDR can go down to 4.0 with 24pinion directly on the counter gear.
416 on right driven by my daughter has won 2/2 races so far in our Tamiya series. TL01 is same dimension (wheelbase, track) but weight much closer to the center line.
Then again, it could be horrible on the track. Will see next Saturday.
Here's my Tl01 running against 2010 model cars a few years ago in 13.5 boost. Lots of fun
https://www.youtube.com/watch?v=QjRQ3NTjmb0
tamiya wrc likes this.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 04-01-2016, 09:26 AM   #437
loosewheel's Avatar
Not to mention that the center of gravity is a mile high on the T L01.
Jody
Greetings from sunny Northern California
Going fast and breaking plastic since 1998.
RELIC RACING
loosewheel is offline   Reply With Quote
Old 04-04-2016, 10:10 PM   #438
DMD
I don't know if this car is still competitive. Next month will be my first time racing electric sedan. I just finished polishing the hinge pins and freed up the steering rack. Still rocking the Novak Switch.
DMD is offline   Reply With Quote
Old 04-05-2016, 06:53 AM   #439
Location: Beneath a rock down by the river. Don't have money for van
Of course it's competitive, just a tub chassis which has influence on handling but not in a bad way. It could be hampered more by it's shocks than by it's suspension geometry. To have even more wow factor I would run a shorty batt with that
( ͡° ͜ʖ ͡°) https://www.facebook.com/becomeasetupguru/
30Tooth is offline   Reply With Quote
Old 04-05-2016, 04:14 PM   #440
DesertRat's Avatar
The old TC3 can still run fine and get you on the track. Your springs are really heavy for rubber tire racing, though.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 04-05-2016, 04:41 PM   #441
howardcano's Avatar
Trader Rating: 35 (100%+)
Very. Associated purples are 30 lb/in. Start at around half of that, with oil to match.
The TC3 is too heavy for TC class, but will do well in VTA, or maybe USGT.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 04-05-2016, 04:58 PM   #442
DMD
Thanks for the advice guys. I will try softer springs. The car is very loose exiting corners. I'm running a Front spool. Shock oil is 50 front 40 rear. Tires are Sweep 36. I am running a LTCR body. The track is unprepped asphalt. I'm not sure if sway bars will help. Any suggestions?
Old 04-05-2016, 05:55 PM   #443
howardcano's Avatar
The spool will make the car loose on corner exit when running on low-traction surfaces. Do you have a ball diff to put in? If you have one that's "crunchier" than another, put it in the front, and the smoother one in the rear.
Howard Cano
Old 04-05-2016, 05:55 PM   #444
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Definitely still competitive in USVTA.
Brian McGreevy is offline   Reply With Quote
Old 04-05-2016, 11:18 PM   #445
DMD
Thanks howard. I'll try the diff and see how it compares. It's very satisfying when you finish a complete rebuild.
Old 04-09-2016, 02:44 PM   #446
https://www.youtube.com/watch?v=SsNUjB4j5n4
Tamiya TL01 test run last night after the TRF class race. Pretty good
Old 04-26-2016, 08:02 PM   #447
i got a tamiya ta01
nova69 is offline   Reply With Quote
Old 04-26-2016, 08:33 PM   #448
Try a little less front droop, but always the same spring in the rear or stiffer, not softer: 19lbs gold springs max in the rear, but mostly blue 17lbs springs all around with 40wt oil/ 25% rebound/ no preload...
bertrandsv87 is offline   Reply With Quote
Old 05-12-2016, 06:08 PM   #449
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Looking for an old TC4 part for a project car. Part # is ASC 31105. One piece motor mount and bulkhead for Factory Team TC4. If anyone has one they are willing to get rid of please shoot me a PM. I figure some of the old school guys may know someone that has one laying around.
Thanks!
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 05-12-2016, 09:54 PM   #450
DesertRat's Avatar
My favorite RCTech thread.
I actually had to put my old JRXS Type R back together, I had intended in earnest to buy a new car but I don't race TC that often and couldn't justify the cash. What's funny it that I use a steel battery tray in the car that as it turns out wasn't exactly flat anymore... I had a very low-tech way of dealing with this involving standing on the plate, the concrete flood ledge in my garage, and a hammer. Worked great.
WCIC '06/'07 grabber Canadian R/C Scene 984 07-05-2007 10:55 PM
Tags
414, kawada, sv-10, tamiya, tc3
