Like Tree3Likes
Old 08-18-2014, 02:38 AM   #256
alcyon's Avatar
Default status report
qualified 5th in the C main13.5 boosted, last position is 7th. in the final put on new rides 32 and this solved most of the problems but car still tended to slide the rear end after 2 minutes. I managed to pick up one position to get 4th place in the final. I over took a car in front of me which I think is a bd-7.
Post mortem.
My car handled great at night, which is when I do most of my impromptu racing with my friends. In Malaysia the track temps during the day is about 38C ambient but the asphalt could go up to 70 C. I did get a few practice runs the week before but the temps at the time weren't any where near as hot as race day yesterday. So the biggest mistake is using the same stiff settings I used for night time to race in the other extreme of temperature. These caused the tyres to over heat and I lost traction. There were countless of times that I had to countersteer. I learnt my lesson and changed setup to cater for the hotter track temps.
I changed to 2 hole pistons with big holes, and 30wt oil all round, from 80wt and 3 hole pistons all around. I also swapped the middle of the chart yokomo yellow springs to my front shocks, and the second softest white yokomo springs to my rear shocks. This should give me more grip all around and more body roll. Droop I kept at 4mm rear and 3mm front.
since the rear springs are also way softer I compensated the shock angle so that I could get faster response.
I was beaten bad yesterday but I aint givin up yet.
http://kawada-alcyon.blogspot.com/
http://superturbooptimamidspecialzx-5.blogspot.com/
kawada sv10 alcyon 3-sanwa mx3x-orca vx v4.1 software-team powers 13.5 motor-turnigy 4200 shorty lipo-savox 1251 servo RIDE RE32
alcyon is offline   Reply With Quote
Old 08-18-2014, 07:18 AM   #257
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Greenbandit View Post
The big question is which one can you get spares for? I love my Barracuda, but parts are scarce.
I have....
Lots of Cuda parts
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-18-2014, 05:43 PM   #258
ShaunMac's Avatar
alcyon:
30wt oil will be very thin in 38C(100F) air temps. Thin oil makes for an aggressive car that will not be kind to tires.
Thicker oil/softer springs work well in hot conditions to keep from cooking your tires during a run. Running your shocks laid down more helps make the car more progressive and smoother to drive. Which also helps with overheating tires. Overdriving is a common reason why a car goes away during a run. Especially on asphalt in hot conditions.
If Ride 32's are the spec tire you HAVE to run, I understand. But if you can go to a harder tire (36's) it will help.
Best of luck to you.
ShaunMac is offline   Reply With Quote
Old 08-18-2014, 05:51 PM   #259
alcyon's Avatar
Originally Posted by ShaunMac View Post
alcyon:
Thanks man, I will keep all of what you said in mind. I will test this 30wt first since my next run will be a night run. Yes the rides are a spec tyre.
I will try 50wt when I plan to test the car in blazing hot temps.
Old 08-18-2014, 08:17 PM   #260
snoopyrc's Avatar
I have only seen the Alex once, but I have been keeping a Serpent S400 going using Tamiya arms, c-hubs, and steering blocks. I don't know if any currently produced parts will support the Barracuda, but if you love it that much then it's worth doing the math. Even if the car you end up with is a Frankenride of sorts.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 08-20-2014, 04:06 AM   #261
EDWARD2003's Avatar
Today I took a detour home and managed to come across what I thought was an abandoned hobby shop. When I walked up to the door there was someone sitting watching tv. I opened the door and everything I saw was a blast from the past. There was so many old and vintage kits and parts from various rc manufactures. The weirdest thing I came across was a credit card sized thing which when you place it on an asphalt track it will tell you the track surface temperature. I think it was by Take Off.
Anyway I kept looking around and stumbled upon these two kits.
HPI Pro and HPI Sport. NIB
EDWARD2003 is offline   Reply With Quote
Old 08-20-2014, 04:08 AM   #262
EDWARD2003's Avatar
Outside of the HPI Pro
Old 08-20-2014, 04:10 AM   #263
EDWARD2003's Avatar
HPI Sport
Old 08-20-2014, 04:11 AM   #264
EDWARD2003's Avatar
Inside - I wonder how old that oil is
Old 08-20-2014, 04:17 AM   #265
howardcano's Avatar
Trader Rating: 35 (100%+)
About 65 million years, give or take a few.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 08-20-2014, 06:36 AM   #266
alcyon's Avatar
Rs4 pro..1998 rc car action car of the year.
Old 08-20-2014, 02:40 PM   #267
Dobbs's Avatar
Trader Rating: 25 (100%+)
Yeah but did you buy them? That RS4 Pro is still a competitor in the right hands.
Dobbs is offline   Reply With Quote
Old 08-20-2014, 05:13 PM   #268
EDWARD2003's Avatar
Well I decided to bid on this and hopefully it will go through.
http://page12.auctions.yahoo.co.jp/j...ion/p422845611
Old 10-21-2014, 10:17 AM   #269
DesertRat's Avatar
How about that. First podium I ever made at a big race.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 10-21-2014, 11:41 AM   #270
maximebeauvais's Avatar
Trader Rating: 6 (88%+)
Very nice....Losi all the way !!!
I still have my losi
Maxime Beauvais
--- www.rcottawa.com ---
maximebeauvais is offline   Reply With Quote
WCIC '06/'07 grabber Canadian R/C Scene 984 07-05-2007 10:55 PM
Tags
414, kawada, sv-10, tamiya, tc3
