Like Tree14Likes
Old 12-03-2013, 06:33 PM   #166
skater-deez1's Avatar
Trader Rating: 60 (100%+)
Questions??
Originally Posted by bertrandsv87 View Post
What I found out was that it's not the old car chassis that got beat, but rather the charger/battery/motor combo .... Once those are upgraded, the old cars are right in the mix....
By the way, December 2012 is not old OK !!! Give a man his due when he's done well against so called better competition !!! Stop hating!!!
When you call it "so called better competition" isn't that you hating on belt cars??? Just looking for clarification but honestly it's always gonna be 90%driver and 10% car.Go ahead and bash me to death for daring to state that but part of the reason his car looks so dialed is because if you watch the video he doesn't overdrive the corners and obviously knows where to run his line according to his set up.The floor is all yours let the bashing begin........
skater-deez1 is offline   Reply With Quote
Old 12-03-2013, 06:47 PM   #167
oeoeo327's Avatar
Trader Rating: 70 (100%+)
Originally Posted by theproffesor View Post
I unfortunately felt I had done all I could with my Pro4. For a while I had set the fastest single lap at my track with it. (I couldnt run consistant laps through a whole race). The car was on rails and everyone that drove it loved it. They said it was so easy to drive fast. But... I took a month off and see my lap time beat by .3 -.5 by several people. When I looked at the chassis they had, all of them were running chassis less than 3 years old. I just dont think the geometry is there, thats prob why the tcxx isnt fairing as well (unless hara was driving it). I am sure the car had more to give, I just couldnt pull it out of it. I think with some minor refinements that a shaft drive, particularly the Pro4, could destroy the other cars out there. Low pro shock towers and shocks, gear diffs, and modern lipo chassis could make the car a beast. I do wish the best of luck to those with pro4's and other older chasiss and hope to see them in front of me on the track. Make me regret my decision to get newer car.
Originally Posted by nf_ekt View Post
Did you run the Exotek lipo chassis on the Pro 4?
I'm running the Exotek Chassis on my Pro 4 - huge improvement over the factory chassis with the battery cutouts.
Having run the car for 5 years in VTA, I could say the following: The car could benefit from a gear diff, but running a spool in the front and the ball diff out back hasn't been a hindrance. As stated previously, the LiPo chassis was a huge improvement. The largest obstacle I haven't been able to address is the shocks - functionally, they're pretty good at performing their job; however, my current setup leaves very little upward suspension travel because there's roughly 8mm between the bottom of the shock body and the shock retainer. The car is quick for what it is, but requires a gentle yet aggressive approach to turn fast laps.
The other thing to consider is that I went WAAAAY out of the traditional setup box to get the car to work on both carpet and asphalt, and both setups are drastically different. I'd try a different set of shocks, but then I'd have to go back to the drawing board to figure out the proper dampening again. Considering the car is one shattered gear case away from life as a parts car, I'm going to avoid reinventing the wheel and simply run what I've got until the replacement chassis is ready.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 12-03-2013, 06:52 PM   #168
theproffesor's Avatar
Trader Rating: 55 (100%+)
Talking
Yeah I had the exotek. I thought it was great, and it helped. But it is one piece to a large puzzle. I would really like to see something like the DLE for the TC4. I know its unlikely since HPI/HB no longer supports the chassis. It would be awesome if HPI released an updated version as direct competition to the VBC Ghost. They could even sell theirs with wheels and tires. :O:O
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 12-03-2013, 07:33 PM   #169
nf_ekt's Avatar
Trader Rating: 113 (100%+)
I think I have one of your old Pro 4's... purchased via (big wave) dave. Exotek chassis, and shell for USGT (grey / green). Was searching through some old Pro 4 threads and it seems to match one of your posts from the past.
What surface did you run your cars on? I'm maybe going to use the car for asphalt VTA.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 12-03-2013, 07:37 PM   #170
Well Skater, so called means that the belt car guys branded themselves better from the start without any solid performance to back it up, but just the number of wins their belt cars had while they accounted for 95% of the total entries. They teamed up and bashed the shaft cars so much it should be a ”Rc hate crime”....lol... These guys pushed belt more than a Macy's shopping cart on black Friday...lol... Now that the Awesomatix, and some tc4's are claiming a few trophies, it's panic time !!! How many new beltdrive cars hit the market in the last two years???? Too many !!!!
And no, I won't bash another fellow Rctech racer, I'll just try to open his eyes to the ”deception”.... You'll know the deception went full circle when Xray comes out with its shaftdrive car....lol..... It's shaft, then belt, then shaft again, .....who's getting shafted here??? Get the picture????
bertrandsv87 is offline   Reply With Quote
Old 12-03-2013, 07:38 PM   #171
Yeah that was mine. I ran it on concrete and carpet. I found some left over diff parts i dont need anymore. PM me and we will talk more about it.
Old 12-03-2013, 07:53 PM   #172
Thumbs up
Your absolutely correct another good example is Associated they sucked me back into the hobby with the tc3 and then my tc4 and then.....a series of dual belt cars? I had no idea there was an ongoing war between drivetrain factions....jesus is this what the hobby has come too? All i can say is put a redcat tc in the hands of the worlds best drivers at a local club race and after he smokes everyone see how many of those pos cars are at the track next week. I absolutely loved my shaft cars but ultimately went belt because I didn't feel like there was any real advantage one way or the other.I still think it's all about the driver,equipment can make a difference but largely it's skilled driving that wins most races.The driver in that video was pretty much spot on in his driving techniques so he made the other cars which could've been all shaft drive(who knows/cares)look silly.
Old 12-03-2013, 08:01 PM   #173
nf_ekt's Avatar
And there you have it folks. The B (vs.) S debates get really old. Just run what you want to run. Works for me.... I like 'em both.
Up the Irons \m/
Old 12-03-2013, 08:11 PM   #174
Thumbs up
Also as a racer on a strict budget nobody appreciates these cars doing well more than i do trust me on that(a $900 rc car is a joke in my book)since i have more important things to spend that money on.The tc4 doing well is great because it's an affordable option for people.I'm not trying to pick on any company in particular with the above statement as i remember seeing the kyosho stallion(tf5 or something i believe)and laughing as with like zero parts availability locally buying that car would be slitting your own throat.It's all kinda funny to me that instead of enjoying the hobby people are battling over belt/shaft.I still have some of the associated stickers that have the red circle with the line through the word belt(you know check us out no belt drive)and look at there direction since then. I would like to see Awesomatix put a great driver on the payroll to back up the claims of the car which shouldn't be much of a stretch as many cars as they are selling at that price.
Old 12-03-2013, 08:15 PM   #175
Thumbs up
Oh my bad didn't realize I was boring you I'm sure spongebob is on where you're at!
Old 12-03-2013, 08:18 PM   #176
nf_ekt's Avatar
Yeah, kind of reminds me of a graphic from the 80's skateboard scene...no bozo's
Fitting enough for this thread!
Up the Irons \m/
Old 12-03-2013, 08:23 PM   #177
Thumbs up
No self respecting skateboarder ever rocked that....trust me.Maybe no fat chicks but definitely not that crap.
Old 12-03-2013, 08:25 PM   #178
The reason I like shaft is because it represents reality, on top of being cheaper to own, maintain,etc... I think shaft is faster in the right hands, but will agree that the driver is everything in Rc and in real life : a bad driver took Paul Walker out, and that Carrera GT disaster of a car should be recalled, PERIOD !!! Just imagine trying to handle a 3.5t boosted T4 on slippery concrete, with a broken front belt: that's a Carrera GT Rc car right there.... No way baby !!!
Old 12-03-2013, 08:27 PM   #179
nf_ekt's Avatar
Fair enough. "Skate and Destroy" was fairly prevalent though . Or any Pushead graphic
Up the Irons \m/
Old 12-03-2013, 08:29 PM   #180
Thumbs up
Yeah now your talking!
WCIC '06/'07 grabber Canadian R/C Scene 984 07-05-2007 10:55 PM
Tags
414, kawada, sv-10, tamiya, tc3
