Old 09-23-2004, 06:33 PM   #16
Regional Moderator
daniz24's Avatar
Originally posted by Charlie
As far as a Tray causing false peaking. It is also a good Idea to let the pack sit for about 10 - 20 minutes before you start charging it. If you take the pack directly from the tray to the charger, you will likely have a False Peak about half way through the charge. I know I usually do.
Yes it's true, I always tray the batteries at night and charge them in the morning. Btw, if any of you using Turbo35 GFX you will see some messy graph voltage when you charge a pack after directly taken from the tray.
daniz24 is offline   Reply With Quote
MRC 959 charger false peaking redrider Electric On-Road 6 12-30-2004 12:59 PM
Charger False Peaking! DOMOisCOOL Electric On-Road 12 10-21-2003 03:20 PM
battery false peaking? xxxtracer32 Electric Off-Road 5 07-22-2003 07:13 PM
wut exactly is false peaking warlord385 Electric On-Road 3 04-22-2003 04:20 AM
False Peaking 3000HVs B3boy Electric Off-Road 20 02-16-2003 08:41 AM
SEO by vBSEO 3.5.0
