Old 09-13-2004, 04:58 PM   #1
Default tc3 roll bar
i think i'm going to get the team associated roll bar kit for my tc3 but before i do i'm wonder if i need to get one for the front and one for the back or both? what ecxactly does it do? and does thickness matter? my suspenshion now is really good i'm very happy with it so now i need a roll bar to make it perfect!
kh15 is offline   Reply With Quote
Old 09-13-2004, 05:18 PM   #2
Speedie's Avatar
A roll bar decreases the amount of weight transfer and side bite in the corner. If one is on the front it will limit the roll in the front and at the same time transfer some of that weight to the rear in the corner.. If both are used and are the same thickness it will help decrease roll at both ends and help eliminate traction roll. Basicly you want to put one on the opposite end that you need more body roll or side bite on in the corners on. A larger bar will lessen the roll more than a thin one. On some low traction surfaces a roll bar is not needed when you need all of the traction side bite you can get.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 09-13-2004, 06:00 PM   #3
i run on smooth asphalt, so should i get one for the front end or back end the turns on the track i race are semi tight?
Old 09-13-2004, 06:15 PM   #4
Jack Smash's Avatar
Trader Rating: 28 (100%+)
Its generally good to have both in case you need to run them on front and rear. Remember though, you usually lose grip on whatever end you put them on. Asphalt tracks generally don't need anti-roll bars unless there is a ton of grip, usually from a surface prep such as VHT.
Jack Smash is offline   Reply With Quote
Old 09-13-2004, 06:47 PM   #5
davepull's Avatar
I would invest in the rool bars. I would also Buy the xxx-main tuning guide it has alot of great info in there.
davepull is offline   Reply With Quote
Old 09-13-2004, 11:54 PM   #6
Wency_TA03R-PRO's Avatar
So bottomline is that its BEST to use the roll bar/sway bar both in front and rear of you TC to attain better performance on the tracks...
Wency_TA03R-PRO is offline   Reply With Quote
G4S roll bar mod - change to mugen roll bar charlesd Nitro On-Road 13 07-01-2008 12:32 AM
Roll Out - 13.5 vs 27t SWTour Electric On-Road 5 02-06-2008 02:31 PM
is my roll out right little man Australian Racing 4 12-22-2007 03:43 PM
roll out kracka Rookie Zone 2 01-21-2007 01:08 AM
Monster GT Roll Cage or Roll Bar complete or Plans? mjm R/C Items: Wanted to Buy 1 03-18-2005 04:12 PM
SEO by vBSEO 3.5.0
