Kyosho TF-5 handling issue
Ran my car for the firstime on an outdoor track today and have a major handling issue.When going fast down the back straight I am letting off for a turn. At this point my rear becomes super light and any input on the wheel causes it to totally lose the rear. I imagine there are several ways to go about solving this. Where should I start?
Cheapest way is try to increase droop at the rear (generally speaking, never owned a TF-5 before).
Droop - Downtravel/downstop.
The rear tires should maintain traction when it lifts up during decelleration
What tyres and body are you using? Is it an rtr tf-5 or kit? Stallion or standard?
I have a dodge stratus rtr, and with the stock body and on not so good rubber it is very slippery in the rear at speed. I ran mine on the weekend with sorex 36r rubber and a protoform Mazdaspeed 6 body and it's much better in the high speed corners it tends towards under-steer. Other issues to sort out though running the sorex wheels.
Eirher shock tension or diff tightness might need to be loosened
Its a kit not the rtr. I put a you saleen body on it. It was working pretty well in the rest of the course. Only went bad when I coasted. No braking.
Tires were a med compound slick pre glued set.
Do you run one-way at all? If you are, try change to spool. Also one-way doesn't like drag brake if you have any. Try rear 3 degrees toe-in with less shock down-travel.
Registered User
Maybe you can fill in a setup sheet and post it here? In that way I'm able to have a look at it..
I will fill one out tonight.
Here's my ASPHALT RUBBER TIRE setup for the SHIN VERSION from when I used to run the K car:
Front
Camber link: Hole 1 with 2.5mm spacer
Shock on tower: Hole 1
Shock on arm: Hole 2
Front suspension block: A w/0mm under
Rear suspension block: In C w/1mm under
Droop: 2mm of lift
Wheelbase: 2mm in front 1mm in rear
Diff height: A w/Spool
Ackerman: middle chassis and top plate block w/forward B in wiper. 1mm under balls on wiper. Outer balls upside down and in back hole on knuckle.
Ride height: 5mm
Toe: 0 deg
Camber: -1.5 per side
Sway bar: 1.3mm with 0mm sticking out
Shock: 3B piston with 500wt Kyosho oil and Xray 2.8 spring. Kit diaphram without the pressure foam. 62mm overall length with 0 percent rebound.
Rear
Camber link: Hole 1 with 1.5mm spacer. Hole 1 on hub w/0 spacers
Shock on tower: Hole 2
Shock on arm: Hole 1
Front suspension block: Out C w/1mm under
Rear suspension block: Out D w/1mm under
Droop: 1mm of lift
Wheelbase: 1mm in front 2mm in rear
Diff height: A w/aluminum diff halves
Ride height: 5mm
Camber: -2 per side
Sway bar: 1.2mm with 1mm sticking out
Hub height: Down. Hubs middle on arm (1mm front and back). Kit hub with 5mm hex's and .5mm wheel spacer.
Shock: 3B piston with 400wt Kyosho oil and Xray 2.6 spring. Kit diaphram without the pressure foam. 61.5mm overall length with 0 percent rebound.
General
SJR 36's with full sauce all around. Tire tweak Sauce. Sauce and heat for 15 min. Hacker 4.5 with 9.0fdr. Protoform Mazda Speed 6 body with stock wing. 1oz of weight in rear on chassis between suspension arms. 1/4oz in front between suspension arms.
Front
Droop: 2mm of lift
Ride height: 5mm
Toe: 0 deg
Rear
Droop: 1mm of lift
Ride height: 5mm
Camber: -2 per side
General
Www crap ran out of time tonight. Will have to do the set up sheet tomorrow. Spooling?
check out the inside of the rims on the rear, if you see i bit of a groove in them you have the same problem i did. On mine the place where the hub carrier attaches to the lower arm, the screw and some of the actual arm, sometimes impact the rear wheels, which slowly wears a groove in them, the excess plastic rubs on the arm, causing extra drag on the wheels and upsetting the cars balance.
funny thing is i have the same problem. ended up busting my shock open. im using preglued rims and some design tyre from japan (or so it says). will do what the rest of u suggested.
