Old 09-12-2012, 05:12 PM   #1471
Suspended
Trader Rating: 86 (100%+)
Originally Posted by CristianTabush View Post
On our website. That's where all the set-ups are posted.
thanks christian
littlealex is offline   Reply With Quote
Old 09-12-2012, 06:20 PM   #1472
gom
Hi, can some body clarify the weights of the RSD spring set?
I always thought they were as follow:
teal 12.5 lb
yellow 13.5 lb
silver 14.5 lb
blue 15.5 lb
silver 16.5 lb
However, I checked the RSD web site and it lists the following:
-11.5 lb/in (Teal)
-12.8 lb/in (Yellow)
-13.6 lb/in (Silver)
-14.4 lb/in (Blue)
-15.5 lb/in (Red)
Which one is correct? I bought one set a while ago and I am planning to buy a second set. Just need to verify the numbers before I hit the order button. Thanks.
gom is offline   Reply With Quote
Old 09-12-2012, 06:24 PM   #1473
CristianTabush's Avatar
The new numbers are the true rated number, the springs have not changed. Just our rating system.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 09-12-2012, 06:57 PM   #1474
Default New RSD Front Bumper
RSD051 RSD Front Bumper for TC6/RSD6
This is our new bumper, it is made a little more solid and wider than the AE version, and is still very light. It requires a bit of trimming underneath to make it fit right, but it has better coverage over the front wheels and is harder. Since it has more coverage it also does not allow the body to flex as much in collisions, which prevents the front fenders tucking into the front wheels, which prolongs the life of your TC's body.
Old 09-12-2012, 07:49 PM   #1475
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
When are you restocking the RSD6 conversion kits?
tr1kstanc3 is offline   Reply With Quote
Old 09-12-2012, 07:58 PM   #1476
Joe, they should be ready around Friday/ Monday.
Old 09-12-2012, 11:35 PM   #1477
Suspended
hey christian, the setup you have posted on here for carpet which you said was great is different from the one you posted on reflex site..on here you say green and blue springs with same bars..on your reflex site, its purple springs all around..which one is it please..lol..thx
.....rayzerdesigns.....www.jconcepts.net...
i am cornholio is offline   Reply With Quote
Old 09-12-2012, 11:45 PM   #1478
I just fixed it. The links were mixed up. The Carpet set-up is labeled as Mike's Hobby Shop - Carrolton, TX. It used Blue Front and Green Rear springs.
Old 09-13-2012, 05:51 AM   #1479
wtcc's Avatar
I just tried to install the DCJs when I recognised that I forgot to order the roll pins (Raaaaah!). Maybe you can add a complete pack to your store (for i..... like me).
Now I have ro ask if there is a shim needed between the roll pin and the ball bearing?
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 09-13-2012, 07:11 AM   #1480
I can vouch for the design of these bumpers... they are pretty wicked pieces.
JamesL_71 is offline   Reply With Quote
Old 09-13-2012, 10:33 AM   #1481
gom
Thanks. Going to place an order tonight when I get home.
Just to clarify one final detail, do these new numbers correspond to the AE spring rates? For example, since the AE silvers are 14.5 lb/in and RSD blues are 14.4 lb/in, the AE silver springs would be a close equivalent to the RSD blue springs?
Old 09-13-2012, 10:57 AM   #1482
geeunit1014's Avatar
Recently, we have been lucky enough to get to test hundreds of different springs on Avid's very cool spring gauge. This machine is super precise and allow us to test our springs and other brand's springs to get actual "TRUE RATINGS". With this, we have decided to start moving our spring ratings around a little bit to reflect this. As of tonight, I will change all the ratings of our springs to the "TRUE RATING" to reflect this. The springs have not changed, just our rating system.
Below are the new rates:
-RSD Teal 11.5
-AE Green 11.6
-RSD Yellow 12.8
-RSD Silver 13.6
-RSD Green 14.0
-RSD Blue 14.4
-AE Silver 14.5
-RSD Red 15.5
-RSD Purple 16.4
-AE Blue 16.6
Keep in mind, these are average for the springs and that the springs from AE to RSD might be similar in rate, however they will behave differently as AE uses different size wire for their springs than we do. Right now, all of our springs are made of 1.4mm wire, AE uses different sizes for different springs.
From a couple pages back. This list is the "true rate" for all the springs on the list
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 09-13-2012, 11:15 AM   #1483
Thank you Mr. Gee
Old 09-13-2012, 12:45 PM   #1484
gom
Thanks Mr. Gee and Cristian. That cleared things up completely. I don't know how I missed that post...my bad.
Old 09-14-2012, 01:00 PM   #1485
RSD6 Conversion kits are back in stock.
They now include the V3 Bell Crank Systems. These are further refined for quicker, smoother steering response.
