Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc) >
Like Tree4Likes
Old 08-28-2012, 01:05 AM
  #1426
Suggestion: paint the springs on the round coil past the end of the ground part, so the paint doesn't rub off.
-Mike
grippgoat is offline
Old 08-28-2012, 07:14 AM
  #1427
mtbboy's Avatar
As if I hit send on my order 3 days ago!!
mtbboy is offline
Old 08-28-2012, 06:42 PM
  #1428
Trader Rating: 20 (100%+)
Default RSD6 body mounting position
I am curious, does the RSD6 chassis use the same body mounting position as the TC6? I have a bunch of bodies painted and am curious if I upgrade will the bodies drop on without any modification in the body post mounting positions.
trailblazer04 is offline
Old 08-28-2012, 06:53 PM
  #1429
CristianTabush's Avatar
Yes, it has the same positions, so that should be no problem.
Mike, as for the springs, I have not really had trouble with the paint coming off, but we will take your suggestion and start marking them differently.
CristianTabush is offline
Old 08-28-2012, 07:06 PM
  #1430
Default Spring Ratings
Recently, we have been lucky enough to get to test hundreds of different springs on Avid's very cool spring gauge. This machine is super precise and allow us to test our springs and other brand's springs to get actual "TRUE RATINGS". With this, we have decided to start moving our spring ratings around a little bit to reflect this. As of tonight, I will change all the ratings of our springs to the "TRUE RATING" to reflect this. The springs have not changed, just our rating system.
Below are the new rates:
-RSD Teal 11.5
-AE Green 11.6
-RSD Yellow 12.8
-RSD Silver 13.6
-RSD Green 14.0
-RSD Blue 14.4
-AE Silver 14.5
-RSD Red 15.5
-RSD Purple 16.4
-AE Blue 16.6
Keep in mind, these are average for the springs and that the springs from AE to RSD might be similar in rate, however they will behave differently as AE uses different size wire for their springs than we do. Right now, all of our springs are made of 1.4mm wire, AE uses different sizes for different springs.
Also, we now have a new spring vendor, which we are very happy with. All our new springs will have a black zinc plated finish, to provide protection from corrosion and also, because they look way better. :P However, this means that once the natural finish springs run out, that's it, they will be no more. All the springs will be replaced by the new "black" springs over time.
Old 08-28-2012, 07:23 PM
  #1431
I also have a list of XRAY, SPEC R (which are identical where applicable to the XRAY Springs, quite impressive!) and Yokomo:
XRAY 2.6: 15.3
XRAY 2.8: 16.5
XRAY 3.0: 17.9
XRAY 3.2: 21.9
SPEC R 2.5: 14.5
SPEC R 2.7: 15.7
SPEC R 2.9: 17.2
SPEC R 3.1: 20.5
Yokomo Black: 13.7
Yokomo Blue: 14.3
Yokomo Pink: 14.8
Yokomo Yellow: 14.9
We are working on a comprehensive spring chart for reference. We will add as we get more springs to try. Our goal is to try to fill all the gaps in between our springs in order to provide a more comprehensive range of springs.
Old 08-28-2012, 08:21 PM
  #1432
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
You da' man CT. Love the free info.
You want me to send you the rest of the Xray springs you don't have in the list? I can also send you a set of Schumacher springs and older Xray colored springs.
andrewdoherty is offline
Old 08-28-2012, 08:24 PM
  #1433
Andrew, yes, please do. I'll bring them back when I come to DFW next Friday.
Old 08-28-2012, 08:32 PM
  #1434
I'll be in my room Thursday and will get them in the mail Friday morning. Ill try to get several sets so you can at least get a 2-3 set average.
Old 08-28-2012, 08:42 PM
  #1435
Awesome!
Old 08-28-2012, 08:49 PM
  #1436
Suspended
thx christian..great to know actual rates of yours and other company springs
i am cornholio is offline
Old 08-28-2012, 08:52 PM
  #1437
arn671's Avatar
Trader Rating: 17 (100%+)
Default Spring ??
Hi CT, not sure if this has been asked/answered? With the AE springs and the reflex springs on the list are they linear rate springs or progressive? Thanks for the info!
arn671 is offline
Old 08-28-2012, 09:24 PM
  #1438
All springs listed are pretty much linear. However, all springs get slightly stiffer as they compress. The lesser the number of coils, typically the more "progressive" a spring will be. This progressiveness comes from the dead coil of the spring and it's relationship to the pitch of the active coils of a spring. A higher pitch angle means less coils typically and my feeling is that since it takes much more force to move the active coils, the dead coil compresses first before it gets into compressing the active coils much.
However, to be true progressive springs, the spring has to have 2 visibly different coil pitches, like the old HPI ones. I have not tested the new XRAY springs, which they claim are progressive, but will soon. My guess is they are using a thinner wire with a higher coil pitch angle to achieve some of this "progressive effect", however, this does not technically make them "true progressive" springs.
Old 08-29-2012, 12:13 PM
  #1439
I didn't have reflex springs long enough to know the durability of the paint long-term, but my HPI springs are definitely having paint rub issues. I like where the Spec-R springs are labelled, hence the suggestion.
The drawback to moving the paint could be that it's easier for people to spy on your spring rates. I don't know if that's important to your customers or not, though.
-Mike
Old 08-29-2012, 07:05 PM
  #1440
wtcc's Avatar
Since driving outdoor this year on a dusty track I can see the blue color vanishing on the spring. So I think for a multiyear use it will be good to find a place for the colour where it does not touch anything, but air
wtcc is offline
