Old 07-31-2012, 08:03 PM   #1366
WD40's Avatar
Not trying to be a smart allic here but what is the point of a rear bumper?
WD40 is offline   Reply With Quote
Old 07-31-2012, 09:36 PM   #1367
Originally Posted by CristianTabush View Post
Mike, the listing is just for 1 pair. I need to get the pics updated... I am not sure if they fit the Schumacher. They fit XRAY and Hotbodies, and I am pretty sure tamiya though. No shim is required.
They look like a straight-through inner bore. Are they 5mm ID?
If you have to ask, you're clearly too fast.
-Mike
Old 07-31-2012, 09:55 PM   #1368
CristianTabush's Avatar
The rear bumper is for preventing body tucks.
Mike, yes they are 5mm straight through.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 08-01-2012, 01:26 PM   #1369
Thanks, Cristian. The slim hexes people are using on the front of the Schui are ~3.85mm, and the stock rears are ~4.85. ID is 5mm all the way through. Is the distance of the pin from the bearing a concern? I didn't measure that.
Anyway, widths are quite close, so I think I'll give yours a try. I am looking to reduce wheel wobbling and slop at the wheel, and want to eliminate worn hexes from the equation.
-Mike
Old 08-01-2012, 01:31 PM   #1370
Mike, the pin is right at the edge of the bearing. I imagine it has to be the same on the Schuie or it would not work right, pushing itself in.
Old 08-01-2012, 01:36 PM   #1371
wiggindude6969's Avatar
I have seen several guys go from 1st to last due to the body tucking in on the rear tire. In most cases it was a lapper letting the faster car go by then the lapper closing the door on the next corner hitting the lead car in the rear.... thus causing the body to tuck in and a corner martial having to fix it! I like the concept! I will be getting one as soon as they are in stock.. Plus it will help the rear blocks stay in place.
F104v2 - RSD/TC6.1 - CRCXTi - AE B6
wiggindude6969 is offline   Reply With Quote
Old 08-01-2012, 01:54 PM   #1372
Suspended
Dennis, we do have the RSD information page on the site, which is really good and also, I try to update on the thread as much as it is possible.
Maybe I can create an email blast for people with an RSD6 chassis, in which they can subscribe to and I can update them on progress. I'll see what I can do.
Now, for an actual update.
I did a lot of testing with the 2.5mm car this last week and I seem to have taken a big leap forward. I did go from a 4.0 to a 5.5 motor which made my car much more driveable, but my car was 3-4 tenths faster than the other guys, vs the usual 1 or 2.
Amongst the changes:
-The rear is now narrower, this made the car have so much more steering than before.
-5mm Hexes in the front: for added stability from the gained steering
-Same 0B roll centers F/R to decrease rear rotation: Making the rear end narrower put a lot of rotation into the car as well.
I will have an updated set-up sheet on the site by tonight on the site, I'll post a couple of more tips as well.
is this on carpet or asphalt
.....rayzerdesigns.....www.jconcepts.net...
i am cornholio is offline   Reply With Quote
Old 08-01-2012, 02:11 PM   #1373
This is on asphalt.
Old 08-01-2012, 02:23 PM   #1374
I'm currently using a frontbumper "Frame" in the rear. So basically the frontbumper without the foam. Works great
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 08-01-2012, 03:38 PM   #1375
Unfortunately, the Schui is not that way. The pin is probably ~2mm from the bearing. The schui hex doesn't actually have a slot for the pin. It has a hole for the pin, and you slide the hex on, then slide the pin through the hex and the axle, and then there's an o-ring to retain the pin.
So depending on how deep the slots are in your hexes, they probably won't work right. I left you a voicemail and sent you an email.
-Mike
Old 08-01-2012, 03:54 PM   #1376
Logi Maker's Avatar
Trader Rating: 49 (100%+)
I'm using a rear shock tower that got hammered at Carpet Nats'11 in the straight when my speedo died..
Anyways have been battling issues on loosing pins on the DCJs and had an issue with the hex spinning in the wheel on the same side on two sets of wheels. Took the screw out and "opened" it up a bit then broke the screw re installing it. Had to put the stock ones back in...won't miss blowing out caster blocks..
Kyle Predmore
Facebook - "AE Fanboy"
B6D|B64D
TC7|TC6TEK|12R5.2|10R5.1
Logi Maker is offline   Reply With Quote
Old 08-01-2012, 04:23 PM   #1377
Kyle, one thing to note is that once you have a pin wiggle loose, you MUST REPLACE the set-screws. Once a set-screw has gotten loose, then it will never again have its holding power back. Best thing to do is always keep a rebuild kit handy.
I will do a tutorial soon on how to build DCJ's so that they last a long time in between re-builds. Making them last is almost an art-form I am finding out. However, when done right they last a LONG TIME. And I mean 3+ months running mod. If not done right, I am lucky if I get 3 runs out of them.
Going forward, with our next production, all our DCJ's will come disassembled. This will make the process of cleaning the parts and installing them correctly easier. There will probably be a couple of revisions to make them better.
Old 08-01-2012, 04:42 PM   #1378
Logi Maker's Avatar
Sounds good ....notch those pins or get with Peter at RC-Trim and get DCJ versions of his Xray ECS wraps....
Keep the good stuff coming..
Kyle Predmore
B6D|B64D
Old 08-01-2012, 05:15 PM   #1379
The pins are not notched because when you do so, it weakens them.
I actually use stretched out 1/4in heat shrink instead of wraps. It works quite nicely.
Old 08-01-2012, 06:31 PM   #1380
racer x 1's Avatar
Trader Rating: 27 (100%+)
+1 on the shrink wrap. Personally i think it would be awesome if they had retaining rings but im not complaining.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
