Old 07-05-2012, 08:53 AM   #1321
CristianTabush's Avatar
Oh yeah, the RSD6 is back in stock!
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 07-05-2012, 09:26 AM   #1322
bradshawkyle's Avatar
Right on, just placed my order! Any hints on what the surprise is or do I have to wait until it arrives?
Seattle RC Racers / Hangar 30 / ARC / Roche
"Speed has never killed anyone, suddenly becoming stationary... That's what gets you." - Jeremy Clarkson
bradshawkyle is offline   Reply With Quote
Old 07-05-2012, 10:17 AM   #1323
Well, our battery mounting system arrived. Pictures and pricing will be up later. It basically eliminates the need for tape. It uses 2 post stand-offs with some keyed carbon fiber tabs.
The way it is designed, it allows for the chassis to flex more evenly from side to side as the battery is not taped down onto the chassis.
As a bonus, it makes battery changes much easier.
I think it should be compatible with the TC6 standard system. I still have to test it for fitment.
Old 07-05-2012, 11:03 AM   #1324
29TC's Avatar
Send a message via ICQ to 29TC
Will the battery mounting system be included in the RSD6 kit?
29TC is offline   Reply With Quote
Old 07-05-2012, 11:34 AM   #1325
No, it is an extra item. Otherwise the price of the RSD6 would have to jump.
We will probably offer it as a package deal though.
Old 07-05-2012, 12:22 PM   #1326
Interesting. I was also trying to make a mounting system without tape
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 07-05-2012, 01:23 PM   #1327
RSD038 RSD6 Battery Hold Down System
Old 07-05-2012, 01:32 PM   #1328
MikeXray's Avatar
Trader Rating: 73 (100%+)
Send Oleg any royalties?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-05-2012, 01:39 PM   #1329
Is that the Awesomatix guy? I saw some a while back, don't remember if they were keyed. The idea is fantastic however, so we decided to incorporate it into our chassis design.
Old 07-05-2012, 01:55 PM   #1330
MikeXray's Avatar
Yes, Awesomatix EP Touring Car (A700 Shaft Drive) It's a good solution either way, I'm sure it will gain popularity, although there is still the possibility of a loose screw causing issues.
Old 07-05-2012, 02:03 PM   #1331
Could be, however loctite is your friend. I have found it to be much safer than tape. The advantage of this is that every run, if you change your battery, you check your screws. That and a little loctite is a nearly fool proof solution.
One thing that is awesome is that it gets flex nearly identical side to side. This is practically impossible with tape and velcro straps.
Old 07-05-2012, 04:14 PM   #1332
Do you think this battery hold down can be adapted to the kit cassis ?
Ed
Edwin Pibal is offline   Reply With Quote
Old 07-05-2012, 05:11 PM   #1333
Yes, you can drill a hole on the cf piece that the tape loops around and it would work. We already have some replacement ones on the way
Old 07-06-2012, 09:02 AM   #1334
briankstan's Avatar
order place for the battery mount.
I'll be running my RSD6 for the first time this weekend. I'm looking forward to it as well, been awhile since I had my TC out.
www.slmini-zstore.com
www.saltlakemini-z.com/forum
www.howfastareyou.com
briankstan is offline   Reply With Quote
Old 07-06-2012, 10:54 AM   #1335
Awesome Brian, I have a new set-up that is pretty killer, I'll try to post it by tonight. Not much different than the last one, except narrower rear end for better steering.
