Old 06-26-2012, 04:37 PM   #1291
CristianTabush's Avatar
Below is a good starting set-up for the 6/6.1
Front:
-1,1,1.5 Piston 550cst oil
-15.5lb spring
-Outside link on tower caps (shorter) 3mm underneath the inside link, 2mm outside (position 3 on turnbuckle will substitute)
-3A Roll center blocks
-4 Deg Caster
-Shocks 3rd hole from the inside on shock tower
-6 on droop
-5mm ride height
-Slipper Spool/ spool tight
-Black sway bar
Rear
-1,1,1.5 Piston 450cst oil
-13.5lb spring
-Outside link on tower caps 2mm underneath inside, 3mm outside (position 3 on tower will substitute).
-shocks 2 holes out on shock tower
-5 on droop
-5.5 mm ride height
-Gear diff 700cst oil
-2.5 inboard toe 1 deg toe hub (if you are not running toe in hubs, 3 degs inboard is enough toe)
-Black sway bar
-5.5mm ride height
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 06-26-2012, 05:37 PM   #1292
Any idea when the rsd6 kit and rear bumper will be back in stock?
riggidy is offline   Reply With Quote
Old 06-26-2012, 05:46 PM   #1293
From what I understand, the new batch of chassis should be done, along with the new battery hold down system this Thursday, so I am hoping middle of next week.
The rear bumpers are on the docket, they will be available again in like a month or so...
Old 06-26-2012, 06:01 PM   #1294
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Questions??
Can I use the rsd pistons with the stock AE bladders
Has any of you tried this combo
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 06-26-2012, 06:10 PM   #1295
Any chance of opening up a preorder?
Old 06-26-2012, 06:18 PM   #1296
Yes, the AE bladders will work with rsd pistons.
Riggidy, I'll put one in stock if you want to order it, just contact me at the store.
Thanks!
Old 06-26-2012, 06:28 PM   #1297
geeunit1014's Avatar
Originally Posted by raypa View Post
Any good starting setup for asphalt on a stock TC6?I have the bladders,pistons and RDS springs.
This is what im currently running: http://racerlog.com/w/images/e/e2/GB_Mod.pdf. I do want to try 15.5s for springs, but the way it is now its very nice to drive
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 06-26-2012, 08:09 PM   #1298
Thanks!
Cristian, i left a voicemail at the shop with my callback number. Thanks
Old 06-26-2012, 08:14 PM   #1299
Got it! I am adding one now in stock.
I was not expecting a VM, but that's cool. It went straight to the answering service...
If you need anything else let me know.
Old 06-28-2012, 03:24 PM   #1300
Thanks for the setup.
raypa is offline   Reply With Quote
Old 06-30-2012, 12:23 PM   #1301
mkennedy's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to mkennedy
hey CT, the chassis' will be available next week?
mike
Mike Kennedy
AKA - Airtronics - F1RCLab - Thunder Power - JGO Paintz - Dialed Inc. - CompetitionX.com
mkennedy is offline   Reply With Quote
Old 06-30-2012, 03:55 PM   #1302
That's what we are anticipating. Late this coming week. We will have a little surprise too!
Old 06-30-2012, 06:35 PM   #1303
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
You're the man CT. Thanks for showing me the ropes. I am really impressed with your car. I learned a lot. Maybe next time I will remember not to pack the rain. I'm rebuilding my shocks tonight and I'll let you know how the o-rings work out. The hex shims are awesome by the way. Can't wait to see what you have coming down the pipe. I'll get some more concrete ideas together for the bumpers and if you want I can send you the motor mount from my VTA. Take care bro. I owe you!
AWD
Old 06-30-2012, 06:51 PM   #1304
No problem AWD, you are always welcome here. Had fun, and thanks so much for the visit.
See you in 2 weeks!
Old 06-30-2012, 07:42 PM   #1305
mkennedy's Avatar
excellent! put me on the list.
Mike Kennedy
