Old 05-28-2012, 05:17 AM   #1171
Hey Cristian,
what's the status on the rsd6 chassis? Close to being Sent out to those who pre ordered?
RCMAKER | BITTYDESIGN | MUCHMORE
Lionel S is offline   Reply With Quote
Old 05-28-2012, 06:47 AM   #1172
Originally Posted by Geberit View Post
This weekend I tried my standard set-up RSD 15,5/14,5 vs. RIDE – Red (approx. 16,9 lb/in all around) on a medium grip asphalt track. The car felt much more stable under braking and acceleration with harder Ride springs. Times were almost the same just that it was much easier to go consistent over a whole run.
What oil did you run? The temps at the track could be (a lot) higher and that does influences damping
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 05-28-2012, 07:07 AM   #1173
CristianTabush's Avatar
Originally Posted by Lionel S View Post
Hey Cristian,
Just waiting on the parts to arrive from the factory. They are on the way right now, so we are at the mercy of the post office, EMS and customs.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 05-28-2012, 09:28 AM   #1174
Geberit's Avatar
Front 40wt rear 35wt air temperature 20 degrees Celsius. Did change only the springs. Used RSD pistons and Bladders!
Geberit is offline   Reply With Quote
Old 05-29-2012, 07:21 AM   #1175
mtbboy's Avatar
Christian,
When Are you going to produce t-shirts, Hats, Stickers and various other Propagana?
"Test your Reflexes"
"Reflex ologist"
"Rsd6.Won"
"I'm a Christian deciple" (oooh racey)
Anyhow, see you in Vegas.
D.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 05-29-2012, 07:34 AM   #1176
Originally Posted by mtbboy View Post
Christian,
"Reflex ologist"
"Rsd6.Won"
D.
Hehehe. Those are all good. I have some quotes out for different decal sheets right now.
Also, we have been thinking about hats. Shirts are always hit or miss and we need too many sizes to stock. We'll see.
I really like the RSD6.won :P
Old 05-30-2012, 09:55 PM   #1177
Trader Rating: 1 (67%+)
Well I'm finally back from the Reedy race, and must say I learned A LOT! First time driving an rc car in over a year and a half and it sure showed. Haha. Had a blast and loved this new RSD6. Changed my setup all week long and finally got it pretty close. I think Christians starting setup was good, but it lacked in the corner entry steering and corner speed departments. I had a top 5 car, but ended up 4th in the B due to the rusty driver. If I knew how to shrink PDF files I'd post my setup. If anyone wants it just ask and I'll email it.
supertech is offline   Reply With Quote
Old 05-31-2012, 07:00 AM   #1178
Trader Rating: 38 (100%+)
One suggestion for durability with the RSD 6. Put either a washer under the screw on the tops of the dual bellcranks or use a cap screw. I hit at full steering lock and the aluminum piece connecting the two arms hopped on top of the screw and cause it to get bound up and stuck. This might only be an issue on the right side.
I would also servo taping the servo in addition to using the L bracket. The L bracket, for me at least, didn't seem to want to stay in position. The screws would loosen on me a bit and then the steering would being to drift.
or8ital is offline   Reply With Quote
Old 05-31-2012, 08:16 AM   #1179
Good suggestions, on both issues. A cap screw would be great.
Using servo tape helps out, even if just a few thin strips. Use loctite on the small M2 screws as well. this helps with holding power.
Canyon, I am glad you enjoyed the car. Please e-mail me your set-up sheet. I am creating an RSD6 reference page on our website and would love to put the set up in there.
Old 05-31-2012, 12:07 PM   #1180
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Cristian, spoke to you yesterday on the phone about my order. Got it yesterday - thanks again for your help!!
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 05-31-2012, 12:49 PM   #1181
Glad you got it!
And as an update, ALL RSD6 parts are almost here. They have cleared customs so they should be here tomorrow/Monday. Once we receive them, we will inspect them and package them and get them on the way ASAP!
I appreciate the patience guys, they will be worth the wait.
Old 05-31-2012, 06:58 PM   #1182
What's your email address?
Old 05-31-2012, 11:41 PM   #1183
contact@reflexracing.net
Old 06-01-2012, 01:46 AM   #1184
Glad you got it!
Nice, good news. Can't wait
株式会社 ヨコモ
Old 06-01-2012, 07:23 AM   #1185
JRXS_chris's Avatar
Woohoo!
Glad you got it!
JRXS_chris is offline   Reply With Quote
