Old 05-23-2012, 12:32 PM   #1156
JRXS_chris's Avatar
After a really, really pants time out at the UK Nationals this weekend I am seriously in need of a boost. Hopefully the RSD chassis will be it
JRXS_chris is offline   Reply With Quote
Old 05-24-2012, 04:29 AM   #1157
Geberit's Avatar
What do you think of this tipe of mounting the LiPo?
Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)-img_3898a.jpg   Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)-dsc_0823b.jpg
Geberit is offline   Reply With Quote
Old 05-24-2012, 05:25 AM   #1158
CristianTabush's Avatar
We already have something like this in the works to test. I am not sure if it's better, but it is very convenient.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 05-25-2012, 01:25 AM   #1159
Geberit's Avatar
You are fast man is there somethin else interesting going on
Old 05-25-2012, 03:10 AM   #1160
Geberit's Avatar
A question regarding springs.
When I read the comments I see you use 13.5lb-15.5lb on asphalt. Now I went through some other top drivers set-ups and see many top people use the HPI silver front and rear that's almost 17lb! And this were setups from ETS Gran Canaria where the traction was more towards low grip.
I spoke to a driver who told me that harder springs have the tendency to get the tires on temperature more quickly. But other ways I know that softer springs should provide a little more overall grip.
Old 05-25-2012, 09:20 AM   #1161
Softer springs do give more grip, but it depends on the track. If the track has much "natural" grip you can go harder on the springs, because else it can "stick" when making turns.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 05-25-2012, 10:22 AM   #1162
Geberit's Avatar
I know what you mean but these days it's just hard to find the right way with this chassis flex options combined with stiffness of the suspension.
Old 05-27-2012, 07:55 AM   #1163
Trader Rating: 38 (100%+)
I have a lot of pre-owned reflex racing & tc6.1 stuff (including an RSD6) for sale if anyone is interested:
Associated TC6.1, Reflex Racing RSD6, PPDBillet, and more blowout
or8ital is offline   Reply With Quote
Old 05-27-2012, 09:01 AM   #1164
Chris08527's Avatar
Trader Rating: 16 (100%+)
anyone have any issues with the pins coming out on the DCJ's and if so what are they doing to fix them???
thanks
chris
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 05-27-2012, 11:52 AM   #1165
There are a couple of things you can do.
1.clean your dcjs with motor spray before you install the set screw.
2.use blue loctite on the clean parts. I recently have found It is best if you apply it on the barrel instead of the screw. Let it cure 30 mins at least before installing the screw.
3.use a very high quality driver. This way you can crank down the set screw without stripping it.
4.if this is not enough, you can slot the pin a bit. This makes them slightly weaker, but it can help the pins from coming out.
5.shrink wrap always helps keeping them together as well.
6.as a last resort, red loctite. It will still come off, but you need a really good driver.
Old 05-27-2012, 02:07 PM   #1166
geeunit1014's Avatar
RSD cleaned up at Jackson RC's 4th annual Memorial Day Race yesterday. Jeff Cuffs TQ'd and won Stock TC, and I TQ'd and won Mod TC. Both of us ran the new DCJs and spool cups. Good stuff
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 05-27-2012, 03:56 PM   #1167
LasagnaCat's Avatar
Trader Rating: 141 (100%+)
Send a message via AIM to LasagnaCat
Waiting very impatiently for this.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 05-27-2012, 07:05 PM   #1168
Good Job Mike and Jeff!
Old 05-28-2012, 02:46 AM   #1169
wtcc's Avatar
I experienced the same yesterday and was surprised! In comparison to the 13,5 spring the 16.5 springs all around made the car better and faster. One of our sponsored drivers even drove AE gold springs all around and the car was dialed.
Christian is there a chance that you extend your range of high quality springs with 17.5 and 18.5?
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 05-28-2012, 04:02 AM   #1170
Geberit's Avatar
This weekend I tried my standard set-up RSD 15,5/14,5 vs. RIDE Red (approx. 16,9 lb/in all around) on a medium grip asphalt track. The car felt much more stable under braking and acceleration with harder Ride springs. Times were almost the same just that it was much easier to go consistent over a whole run.
