Old 05-16-2012, 12:39 PM   #1111
Trader Rating: 38 (100%+)
Can't wait to get mine back out there were the corrected setup. Saturday can't come soon enough.
or8ital is offline   Reply With Quote
Old 05-16-2012, 01:04 PM   #1112
CristianTabush's Avatar
Originally Posted by Geberit View Post
Mine is on the way to Europe. Can't wait to try it on our low/medium grip asphalt tracks.
Would be nice to hear from US guys who already got their kits ... specially if they tried it back to back with the original kit.
About the top deck it would be nice to have different thicknesses let's say 2.0mm; 1.8mm; 1.6mm?? Instead of just different cut variations.
We will probably have at least one 2mm top deck soon. However, I am not sure if we will make different thickness ones as the other sizes are non-standard carbon and we need to order a lot of material to get them done, it just is not cost efficient.
We are considering a 2.00mm option lower deck for extreme situations, but we still are in planning stages. The chassis has to be cut differently or it would be too soft.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 05-16-2012, 01:10 PM   #1113
Geberit's Avatar
Oh that's a point I didn't think of that. Some posts back you mentioned you will explain how to cut the top deck. Any suggestions on that?
Geberit is offline   Reply With Quote
Old 05-16-2012, 01:20 PM   #1114
Yeah, I'll post a pic in a bit... Gimme 10 mins or so....
Old 05-16-2012, 01:25 PM   #1115
What's the "best" / easiest way to "cut" the top deck?
Thanks.
Old 05-16-2012, 01:44 PM   #1116
Default RSD6 Flex Cut Top Deck
Old 05-16-2012, 02:24 PM   #1117
geeunit1014's Avatar
Thanks.
If you mean what to cut it with, just use a dremel. Cut off wheel and sanding drum. Cut it where CT shows.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 05-16-2012, 03:38 PM   #1118
For the standard RSD setup is the rear outer ball position A or B?
Old 05-16-2012, 03:40 PM   #1119
Whatever the shorter link is.
Old 05-16-2012, 03:44 PM   #1120
Thank you sir!
Old 05-16-2012, 03:54 PM   #1121
Any news of the project of alloy standard bones ?
Fred
fredB is offline   Reply With Quote
Old 05-16-2012, 04:13 PM   #1122
Soon, it's on the docket. Just waiting on some quotes.
Old 05-16-2012, 08:25 PM   #1123
mkennedy's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to mkennedy
CT, the bearings for the tc6 and the dcj's, i tried to use the 5x10x4 and they are wider than the steering block recess. should i have used a 5x10x3 instead? did i miss something?
mike
Mike Kennedy
AKA - Airtronics - F1RCLab - Thunder Power - JGO Paintz - Dialed Inc. - CompetitionX.com
mkennedy is offline   Reply With Quote
Old 05-16-2012, 08:34 PM   #1124
Yes, if you are using a TC6, you must use 5x10x3 bearings. The TC6.1 uses 5x10x4's.
Old 05-16-2012, 10:16 PM   #1125
Default New Products
Nothing major, but we do have 2 new offerings:
RSD028 RSD6 Servo Saver Set
Comes with 18mm Aluminum horn, great for the RSD6 and other Dual Bell Crank TCs.
RSD031 RSD 4mm E Clips
These are the lay shaft e clips. I hate it when I lose one, so it is a great thing to keep spare.
SEO by vBSEO 3.5.0
