Old 05-10-2012, 07:23 PM   #1066
Trader Rating: 38 (100%+)
Originally Posted by CristianTabush View Post
Antenna should mount on the top deck. A hole has to be drilled. This is at least how I am doing mine. You can always mount a seis fan with our 25mm bracket and fan mount. Therebis still a hole behind the motor to achieve this.
Have the fan mount (but not the bracket). Trying to figure out how best to do it with the mount. I can shim the mount with two 4mm shims or mount to the top rather than bottom of mount. Still working on it.
As for antenna on the top deck the spektrum antenna is only about 1" high. Trying to see if it's even worth it. Ha ha.
or8ital is offline   Reply With Quote
Old 05-10-2012, 07:38 PM   #1067
Here are my options with the fan and mount:
Old 05-10-2012, 07:40 PM   #1068
I think a great product idea would by just a straight post for the single hole that a 25mm fan could mount to directly on top of the chassis.
Old 05-10-2012, 07:52 PM   #1069
snoopyrc's Avatar
Hey Snoopy, we will start with Pistons for the Photon. The bladders already fit.
We will also follow that with DCJ's for it as well.
Yeah The DCJs for the photon are peaking my interest. I have been asking around about that and it seems the best option is to use the X-ray C hub and an arrowmax DCJ for the T3. So if you have a simpler option I would be interested.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 05-10-2012, 08:05 PM   #1070
CristianTabush's Avatar
Got it! I'll work on something. We also have the fan mount base that can be servo taped in the meantime.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 05-10-2012, 08:14 PM   #1071
There just isn't enough surface space behind the motor for servo tape to hold. The fan kinda flops around on the tape. Suspect the fan mount base would do the same. Would have to move it up to the front of motor.
Hopefully you aren't taking any of this as whining or complaining. I think this thing rocks. Just pointing out observations.
By the way I tested it and the fan fits behind the motor just fine if it were mounted to a straight post in the rear. I fabricated something with a plastic tamiya servo mount to test and it seemed like if properly done it would work really well.
Old 05-10-2012, 08:35 PM   #1072
LasagnaCat's Avatar
Trader Rating: 141 (100%+)
Send a message via AIM to LasagnaCat
I've tried running ours mounted both ways... motor came off roughly the same temp with the fan over or under the mounting arm. Ended up doing the same thing with the washers underneath the base, ours didn't have to go quite that high though... I'd just run it mounted on top before having it perched that high on one leg.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is online now   Reply With Quote
Old 05-10-2012, 08:48 PM   #1073
That's what I will do for now. I think on the chassis will be better long term. Lower weight and less susceptible to damage.
Old 05-10-2012, 08:54 PM   #1074
Trader Rating: 1 (67%+)
Man it's killing me seeing everyone else get their RSD6 built! I'm still running to the mail box every night after work!
supertech is offline   Reply With Quote
Old 05-10-2012, 09:09 PM   #1075
I know it's not complaining. We take all the feedback to heart and act upon it.
Old 05-10-2012, 09:49 PM   #1076
One final observations. There aren't any chassis balance holes. Will see if I can get away with using the center bumper screw and forward/center motor mount screw.
Old 05-10-2012, 10:01 PM   #1077
No balance holes.
I did not think they were necessary as the shock towers have holes in the center to balance the chassis. You can either use a string to balance it or you can us two thin wrenches.
Old 05-11-2012, 02:05 AM   #1078
Geberit's Avatar
I see a new top deck on the picture. Can you poste some spy photos of top decks you'r testing?
Geberit is offline   Reply With Quote
Old 05-11-2012, 07:22 AM   #1079
That's our cut TC6 Top deck. I'll post some pics with some suggested cuts later today if I can.
Old 05-11-2012, 08:56 AM   #1080
hi my order is RX5259, i have not received the order yet,just thinking can i change the blue bellcrank to a black one ...? dont mind waiting ...
vm2 ,tm e4,mi 4,cup racer,yokomo d1,TCX,PHI RDX,MI4CX,TC6,china made pro-d.
ps.just came back to this hobby this year after22 years .
oldnoob is offline   Reply With Quote
