Old 05-10-2012, 06:47 AM   #1051
CristianTabush's Avatar
Default Pics of RSD6
I leave you with some teaser pics.
And the standard set up:
https://reflexracing.3dcartstores.co...ard_Set_Up.pdf
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 05-10-2012, 10:06 AM   #1052
briankstan's Avatar
are there mounting locations for the RSD motor Fan mount on the chassis?
www.slmini-zstore.com
www.saltlakemini-z.com/forum
www.howfastareyou.com
briankstan is offline   Reply With Quote
Old 05-10-2012, 10:15 AM   #1053
There is still 1 screw hole for it. it is more than enough to hold it in place
Old 05-10-2012, 10:43 AM   #1054
briankstan's Avatar
that works for me.
Old 05-10-2012, 11:11 AM   #1055
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Chassis looks great! Good job.
☆ Joe Tran ☆
tr1kstanc3 is offline   Reply With Quote
Old 05-10-2012, 12:18 PM   #1056
Nice pictures. Quality control seems high, can't wait.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 05-10-2012, 01:44 PM   #1057
Default Solaris Tires
We now have Solaris Hard Spec tires for sale at the shop!
Old 05-10-2012, 02:50 PM   #1058
snoopyrc's Avatar
Do you have any more Photon Love in the works? Should I look back through this thread or is there another one? Chassis looks great by the way.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 05-10-2012, 02:50 PM   #1059
snoopyrc's Avatar
One click = Two post. I dont know why it does that.
Old 05-10-2012, 03:08 PM   #1060
Hey Snoopy, we will start with Pistons for the Photon. The bladders already fit.
We will also follow that with DCJ's for it as well.
Old 05-10-2012, 05:14 PM   #1061
DARKSIDE's Avatar
ygpm
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Scale Nationals
Windy City RC in Arlington Heights IL
April 8-9
DARKSIDE is offline   Reply With Quote
Old 05-10-2012, 06:02 PM   #1062
Trader Rating: 38 (100%+)
Got my RSD together tonight. Couple things:
- the offset screw is really so slight. If you change the order you install the screws you wouldn't even notice. I think that speaks to how high quality this is.
- I didn't realize it doesn't come with a new turnbuckle link. What length is appropriate for that?
- I assume I'm supposed to cut the bottom ear off the servo on the outside?
- the belt tensioner works much better with the new chassis and the revtech lipo. no problems whatsoever
- pictures do not do it justice on how narrow the chassis is. You will be quite surprised when you first see it.
Here is a picture pre electronics.
or8ital is offline   Reply With Quote
Old 05-10-2012, 06:38 PM   #1063
Looks awesome!!!!
I did an ooopsy! I forgot your steering link. It's just a long 20mm set screw. I just realized that right now. I will send all of ya'll steering links tomorrow.
There is no need to cut the whole servo horn off, you just need to trim it like 2-2.5mm to clear the bracket. The servo mount is intended to be used with the lower hole.
Old 05-10-2012, 07:08 PM   #1064
I found a 25mm turnbuckle that looks like it will work for me so no need to make an extra shipment for me. You can ship mine with the rest of my stuff.
Couple more observations:
- no antenna mount holes. Shouldn't be a big deal with my short antenna. I hope.
- the seis fan is gonna be a challenge to mount. Still working on how best to do it.
- for now I just shimmed the right servo post the same high as the left and I'm using the stock mount. This obviously will put weight higher but it might work out better for me. I usually have to add significant weight to my electronics side and the tungsten weights I use now slide under the servo to lower that weight.
Old 05-10-2012, 07:15 PM   #1065
Antenna should mount on the top deck. A hole has to be drilled. This is at least how I am doing mine. You can always mount a seis fan with our 25mm bracket and fan mount. Therebis still a hole behind the motor to achieve this.
