Old 05-01-2012, 08:06 PM   #991
CristianTabush's Avatar
Default Chassis are on the way from the Factory!!!
In the meantime, I leave you with a picture of the final production versions
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 05-01-2012, 08:12 PM   #992
Wattsup23's Avatar
Trader Rating: 29 (97%+)
Wow the chassis looks great!!
Team Watts Racing
Wattsup23 is offline   Reply With Quote
Old 05-01-2012, 08:14 PM   #993
Jorge T's Avatar
Sweet
Jorge T is offline   Reply With Quote
Old 05-01-2012, 08:46 PM   #994
Holy..................... why do you gotta tease us like that
Little John is offline   Reply With Quote
Old 05-02-2012, 01:43 AM   #995
Trader Rating: 38 (100%+)
How does the servo mount? I'm confused by looking at the pic.
Edit: nevermind. I figured it out.
or8ital is offline   Reply With Quote
Old 05-02-2012, 07:23 PM   #996
scoot2539's Avatar
Is there a DCJ rebuild kit? If not what size is the pin?( I lost one this weekend and I even had it lock tighted in.)
Scott Hartman
TEAM ASSOCIATED - AKA - TEKIN - FUTABA
scoot2539 is offline   Reply With Quote
Old 05-02-2012, 10:31 PM   #997
The re-build kits are currently being made. However the pin is a 1.5mm pin, the same as XRAY ones.
Make sure that when you tighten the set-screw, you are using a high quality driver. Also make sure that you allow the loctite to cure for best results. For the ultimate solution you can notch the pin and/or use some heat shrink on the DCJ.
Of all the things above, I only use the loctite method, with a quality, big handle driver in order to torque the set-screw sufficiently so that they don't come out.
The only pin I have lost was when I did not use loctite when I first tested the production versions. After I did, I used some loctite and the failure has not come back.
Old 05-03-2012, 04:20 AM   #998
Looking good Cristian. Can't wait to try it out
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 05-03-2012, 06:26 AM   #999
DARKSIDE's Avatar
did some testing with the TC6 w/ RSD upgrades....
nice very nice...12.6 fast lap...prev...13.3 from last Sunday race that I TQ'd
Ive added:
RSD 4.3mm 7075 T6 Hard Anodized Aluminum Ball Ends - 4 pcs. (3mm thread -1mm height)
RSD AE TC6 Belt Tensioner/ Battery Spacer
RSD TC6 12.5lb Spring (TEAL)
RSD TC6 13.5lb Spring (YELLOW)
RSD TC6 Sway Bar Collars
RSD TC6 Vertical Stud Shock Tower Mounts (2 Pair)
RSD TC6/AE 10mm Machined Delrin Piston (1.0,1.0,1.5mm)
RSD TC6/AE 10mm Soft Bladders
still on the box stock setup...just replaced the parts...going to start a little tweeking Sunday to see if low 12's are in my future
PS: I have the DCJ's , just waiting on bearings...and we run on a 95x50 carpet track
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 05-03-2012, 06:16 PM   #1000
Bought the belt tensioner. It looks to push the battery further out vs the stock piece and now my battery (rev tech 6500) doesn't fit. Is there a way to make it work?
Old 05-03-2012, 07:31 PM   #1001
chevtech23's Avatar
I had to file my battery retainers a bit. wasnt a big deal i did it a little at a time till i got the exact fit i wanted.
chevtech23 is offline   Reply With Quote
Old 05-03-2012, 09:00 PM   #1002
Default will there be battery retainers in the chasiss kit ?
i see some holes for battery retainers on the chasiss , are you going to make these battery retainers ?will it be included in the chasiss package ?
vm2 ,tm e4,mi 4,cup racer,yokomo d1,TCX,PHI RDX,MI4CX,TC6,china made pro-d.
ps.just came back to this hobby this year after22 years .
oldnoob is offline   Reply With Quote
Old 05-03-2012, 10:31 PM   #1003
Yes, the battery retainers do come with the chassis kit. They are slotted so that you can adjust your battery a bit, based on the size of the packs.
As for the belt tensioner, it is designed to push the battery a bit away from the belt. Some batteries are slightly bigger than others so it is necessary to make the plastic pieces "square". If you look at them closely they are a bit angled towards the inside. Another option is to heat them up a bit and bend them out slightly.
I will work on an installation tutorial over the weekend. Sorry it has taken this long, it's just been so busy that I honestly forgot.
Old 05-04-2012, 07:11 AM   #1004
Mine is quite a bit more than slightly away from the best. It's about 8mm. Hmm. I will just wait for the new chassis and see if it works for me there.
Old 05-04-2012, 07:25 AM   #1005
DARKSIDE's Avatar
mine works perfect...
but I was wondering about stickers/decals...Ive done 1 1/2 cars and do not have anything to advertise
can I get some please
