Old 04-22-2012, 10:49 AM   #931
scoot2539's Avatar
Originally Posted by CristianTabush View Post
I just put some more back in stock.
Thanks!
Thank you very much.
Scott Hartman
TEAM ASSOCIATED - AKA - TEKIN - FUTABA
scoot2539 is offline   Reply With Quote
Old 04-22-2012, 01:05 PM   #932
No worries, no one will yell at you here.
As LasagnaCat stated, you must run at least 2mm of spacing on the standard mounts or the offset mounts. Right now the hot set-up is with a little arm sweep. I am personally running 3.5mm of spacing in the FF mount and 3.0 on the FR.
how about th rear do you space them out by 1.mm even when you are using the offset ?
vm2 ,tm e4,mi 4,cup racer,yokomo d1,TCX,PHI RDX,MI4CX,TC6,china made pro-d.
ps.just came back to this hobby this year after22 years .
oldnoob is offline   Reply With Quote
Old 04-22-2012, 03:15 PM   #933
CristianTabush's Avatar
I don't use the offset mounts, as I still prefer to run 8 block locks, so my rear spacing is set at 1.5RF and 4.3RR which yields right around 3.5 degrees of rear toe.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 04-22-2012, 03:32 PM   #934
Would you like to reply on my PM Cristian? ;-)
Can't wait for the chassis to arrive. TC6(.1) + RSD = A beast!
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 04-22-2012, 04:15 PM   #935
Sorry, sometimes I miss the PM's. I am gonna go take a look at it.
Old 04-22-2012, 06:14 PM   #936
Trader Rating: 38 (100%+)
Will the RSD6 include a servo saver or will I need to purchase one? If so, any suggestions?
or8ital is offline   Reply With Quote
Old 04-22-2012, 06:18 PM   #937
LasagnaCat's Avatar
Trader Rating: 142 (100%+)
Send a message via AIM to LasagnaCat
The DCJ's were solid, but I need to stress this: USE LOCTITE on the Set screws.
Older post, but a BIG +1 on this one.
First race-day of the year today, TQ in my class and ended up fourth in the main with the car that would just randomly spin in weird places... sure enough, loose set screw and no loctite = really bad.
Other than the rookie 101 mistake from the 'should have known better/DUH!' category, the car ran great with all the Reflex parts... thanks Christian!
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 04-22-2012, 07:26 PM   #938
No servo saver included. Any long servo saver will work, the taller the better I think. Personally I recommend a metallic gear servo with an aluminum servo horn. Core RC sells a really cool one that has overlapping holes:
http://www.amainhobbies.com/product_...nwa-Airtronics
This is the one I use. Through all of our testing we have not stripped a servo, however I do run metal gears. I have noticed most European Pros don't run servo savers either. I feel it makes the car track more straight.
With the regular TC6 single crank, I used to lock down my servo saver as well, so you should be safe so long as you don't constantly beat on walls.
Old 04-22-2012, 07:57 PM   #939
geeunit1014's Avatar
If you want to run a saver, get a Kimbrough mid size.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 04-22-2012, 09:45 PM   #940
The kimbrough mid size is not ideal length. It is a bit short. The RSD6 has high steering bellcranks so you would be better served with something taller. Otherwise you will not have full throw or you will have slow steering.
3racing makes a long/tall servo saver that's a copy of the Tamiya ones, which would probably be best.
Old 04-22-2012, 10:52 PM   #941
Trader Rating: 1 (67%+)
Any updates on when the RSD6 kits will start shipping? Getting pretty anxious to try it out!
supertech is offline   Reply With Quote
Old 04-22-2012, 11:10 PM   #942
Default 5x10x3 bearing for DCJ in
Hi All,
Which brand/type 5x10x3 bearing are people using with the DCJ in the TC6?
Cheers.
gazmanster is offline   Reply With Quote
Old 04-23-2012, 06:26 AM   #943
+1
Little John is offline   Reply With Quote
Old 04-23-2012, 06:36 AM   #944
VAzRACER's Avatar
Trader Rating: 17 (100%+)
Originally Posted by gazmanster View Post
Hi All,
Cheers.
I've been using Avid's for a while now. Durable and cheap.
Reflex Racing / Psycho Cells
VAzRACER is offline   Reply With Quote
Old 04-23-2012, 06:39 AM   #945
They should start shipping sometime next week.
