Old 04-14-2012, 12:43 PM   #886
JustWill75's Avatar
Send a message via AIM to JustWill75
Originally Posted by VAzRACER View Post
I've been using a dremel as mentioned. One of the sanding drums I have is about 10mm so I just run the through and it's good. Takes about 2min to do a pair. I wouldn't worry about breaking them much, I've had the same set on my car for about 3 months with no issues.
ok thats good to know
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 04-14-2012, 05:20 PM   #887
The Teacher's Avatar
Trader Rating: 48 (100%+)
Did any of you guys have problems with the DCJ's being too long? I have the front of my car spaced out 1.5mm in the front at the arm mount and the DCJs still bind when the suspension is moved up and down.
The Teacher is offline   Reply With Quote
Old 04-14-2012, 06:00 PM   #888
Try 2mm spacing. This is the standard spacing for the 6.1.
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 04-14-2012, 06:31 PM   #889
JustWill75's Avatar
Joe is right
Old 04-14-2012, 07:31 PM   #890
geeunit1014's Avatar
1.5mm with a non offset mount? Definitely go wider. Im running 3mm on a non offset mount
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 04-14-2012, 07:48 PM   #891
CristianTabush's Avatar
I've run 1.5mm before, but with the slipper spool, are you running the new spool by chance?
In any case, personally, I never run anything under 2.0mm. And now with the RSD6, I am at 3.5FF and 3.0FR spacing. The car still has plenty of steering which baffles me. I got this from Mike G at the carpet nats and when I tried it on asphalt, I liked it so I have not changed it. The ROAR carpet nats was the last time I ran a regular TC6.1 though...
Joe, Mike, Will, thanks for the help and feedback.
Matt, thanks for the tips.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 04-15-2012, 07:26 AM   #892
I spaced it out to 2.5mm and problem solved...
Old 04-15-2012, 08:26 PM   #893
Just ordered some springs, bladders, pistons and DCJ's yesterday! Can't wait to try them out!
jmann591 is offline   Reply With Quote
Old 04-15-2012, 08:32 PM   #894
easye's Avatar
I also just ordered dcj's where is this shimming go? Any one have a pic?
b5m tekin r1
rc8b3 werks
rc8b3e hobbywing
leisure hours hobbies and raceway. Ez duz it customs.
Al Richards #1 fan Mr.Mellow #5 fan
easye is offline   Reply With Quote
Old 04-15-2012, 09:43 PM   #895
Wink
The shimming that is talked about is the front suspension blocks. TheDcj's are designed for the 6.1 stock offset blocks which are 2mm offset (or the old blocks with 2mm spacing).
Hope this helps.
Old 04-16-2012, 09:59 AM   #896
JustWill75's Avatar
DCJ's are installed and I can't wait for my first race with them. I also built my shocks with with the soft bladders and all I can say is THEY ARE NOW AS SOFT AS NICKI MINAJ'S BOOTY. Wednesday night is a series race at HOTSHOTS RC in Marietta GA so I'll see what happens.
Old 04-16-2012, 10:22 AM   #897
To me, making the car wider by shimming the arm will add traction to that end. So even though the front is wider, you still have steering, but the car is a little more predictable. I ran that same shimming on asphalt most of last year, but I do want to play with making the car narrower for asphalt again
Mike Gee
Old 04-16-2012, 11:58 AM   #898
Mike, even though it might seem like it to you, let's not write incorrect statements. A wider car decreases lateral weight transfer, which takes away traction at whichever end you do this to. This is why cars are run wider on carpet, like you said, to make the car easier to drive.
There is no question, If I narrow my front end my car will get more steering, but it won't be as stable. The new chassis has more steering than the TC6 and this is probably why the front end is working well being wide.
Old 04-16-2012, 12:25 PM   #899
JustWill75's Avatar
Is it better to make the car wider from the wheel hex or from the bulkhead on carpet?
Old 04-16-2012, 12:28 PM   #900
What you said is true if you are only changing the track width. Spacing out the arms also changes the roll center to make the car roll more (you are making the upper link longer spacing the arms out).
Mike Gee
