Old 05-24-2011, 11:18 AM   #61
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Originally Posted by CristianTabush View Post
These are our new TC6 Arm Mount Shims.
These Shims provide more stability for the TC6 A-Arm mounts, preventing them from rotating out of position which causes the dreaded A-Arm slop . They are compatible with all the TC6 Suspension Mounts in either A or B hole.
The shims are interchangeable left to right and front to back. A total of 4 shims is recommended for each car, (one on each side of the rear suspension mounts front whether in the front end or the rear end) but up to 8 can be used.
The shims are Aluminum and finished in Black Anodization, like our Vertical Stud Shock Tower Mounts. They are 1.5mm in width, which is roughly the same width as the Box Set-Up and are compatible with the stock plastic shims, or the more precise Aluminum M3 Suspension Shims.
Very nice!! I like! But I would have to change kits to use these...
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 05-24-2011, 12:11 PM   #62
JayBee's Avatar
Trader Rating: 31 (100%+)
Hey Christian, if you have any pistons sets left over let lemme know
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-24-2011, 01:46 PM   #63
CristianTabush's Avatar
Default Pistons
JayBee, we have TONS of Pistons left over
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 05-24-2011, 03:46 PM   #64
daleburr's Avatar
Dale, what stops the shims from rotating is the increased surface area friction. Our first design used a grub screw, as we thought it would be necessary, but we found that it made the suspension mounts too rigid.
This had several different effects
-Decreased traction- The mounts just would be "too solid" is what we inferred.
-Increased damage in strong collisions: Since there was nothing to "give" either the bulkheads would get bent, the arms would break and/or the hinge pins bend. We are talking hard though, not your regular hits.
We then tested the non-grub screw model, it worked much better. Not only are they easier to use, but they provide more consistent traction. We did not have a single instance of the Shim moving or getting loose which prevented the Arms from developing the slop. It is much like the CF shaped shims some people (You?) were cutting, but with a "stop" built into the back of them. The Center hole in the shim is used at the A or B hole, which puts equal force on both ends of the shim at any position. The stop (or flange) comes out 5mm, which enables you to use more than plenty aluminum shims to space out your car/ incorporate rear toe as much as 5.5 mm at any end when you are using these shims. Another benefit of having no grub screw is that in high speed collisions there was less damage to the car.
Makes total sense; I am using carbon shims which prevent the rotation in the same way (increased friction), but can still move in a crash to prevent damage.
Since the carbon shims aren't commercially available and most people don't have access to lots of thicknesses of carbon fibre I would think your new shims will be very popular. The mount rotation is the biggest problem with the TC6 out of the box and these will solve it nicely. A very simple, effective solution I think.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 05-24-2011, 04:50 PM   #65
Jochim_18's Avatar
Any of this upgrade parts will be available at REEDY?
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 05-24-2011, 07:50 PM   #66
We won't be at the Reedy Race, however we have shipped some products that way already. So you might start seeing some in the Pits.
Old 05-26-2011, 09:58 AM   #67
Chaz955i's Avatar
Sorry if I missed it buy when are the shims going to be available?
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 05-26-2011, 10:08 AM   #68
Shims will be ready in 4-5 weeks.
Old 05-26-2011, 10:12 AM   #69
Chaz955i's Avatar
Excellent. Thanks for the update.
At The Gate Bizzos
Old 05-26-2011, 11:53 AM   #70
Springs just got here!!!
They will probably ship on Monday. The color markings that were supposed to be done to them were done poorly though. We have to go in and re-color them properly There goes my weekend
Old 05-27-2011, 03:07 PM   #71
Default Production Shim Samples and Product Shipping
So... Good track day yesterday. The production shims are awesome! Not once did they come loose. Suspension mounts stayed in place all night long, and not once did I have to re-tighten them. Typically, every 2-3 runs they will develop about 0.5-1.0 mm of slop. Not last night. As expected, only the rear mounts (at rear end and front end) really need them, if you want a more solid set-up 8 instead of 4 shims can be used.
We are also making good strides with the springs packaged up, seeing as this is a long weekend, remaining product from partially shipped orders, as well as international orders should all ship on Tuesday.
Some of you should be starting to receive your first items around these days. Make sure you drop by and give your impressions and ask any questions you may have.
Old 05-27-2011, 04:35 PM   #72
xtrememadness's Avatar
Send a message via AIM to xtrememadness
thank you cristian! i just recieved my package of vertical mounts and pistons! just in time for racing tommorrow the springs are coming and i will order the shims when they are ready! thanx again
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 05-28-2011, 12:27 AM   #73
JayBee's Avatar
hey christian do you remember off hand if you shipped my items? 98444 zip code....
Old 06-01-2011, 11:39 AM   #74
Default All orders shipped!!!
Great news! We are all caught up with all the pre-orders, including dealers. If you placed an order for anything, or were waiting on anything else, the parts are all on their way.
If you were waiting for everything to be in stock to order, now is your chance!
Old 06-01-2011, 03:56 PM   #75
JayBee's Avatar
Yeah, just waiting on my stuff to arrive.
SEO by vBSEO 3.5.0
