Old 01-26-2012, 10:16 AM   #706
mtbboy's Avatar
Thanks Christian,
Tight, Med high Grip Carpet.
17.5 Boosted like Whitney Houston.
D.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 01-26-2012, 04:30 PM   #707
burgboyz's Avatar
Trader Rating: 70 (100%+)
...like Whitney Houston. hahahahahahahaha!!!!!!! lmao
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Old 01-27-2012, 07:45 AM   #708
CristianTabush's Avatar
Try this:
Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)-tc6_fallclassic_tabush.jpg
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is online now   Reply With Quote
Old 01-27-2012, 08:09 AM   #709
mtbboy's Avatar
Perfect.
Thank you Sir.
D.
Old 01-27-2012, 10:15 AM   #710
Originally Posted by CristianTabush View Post
f1o7x9- regarding the pistons, how are they not smooth? did you check them to see if they had any rough edges? They should be just as smooth, if not smoother than the stock units. If you feel like you received some defective ones, I will replace them free of charge. You should not have to sand anything though. Double and triple check that it is the pistons and not something else that is causing this. Not saying it could not be the pistons though. Sometimes, stuff can be out of spec.
mtbboy- I have a couple of set-ups on the thread here somewhere. What surface are you running on? I need to know so I can point you in the right direction.
So i went home and I checked the piston, the pistons look really smooth, I didn't sand them and I tried all of them on some new set of shocks and on my old shocks and they where the same results. I put back the old ones and it was nice and smooth, the only thing that I could see that was wrong was that your pistons where not the same size they are a little smaller so when they where inside the shock body there was a little slop
f1o7x9 is offline   Reply With Quote
Old 01-27-2012, 11:00 AM   #711
Run them in on the track. I noticed yesterday after building my new car that the shocks felt a little "scratchy" with all new parts yesterday. On my old car, this was not the case.
However, after a couple of runs, I noticed everything got smooth on the car. Now they are as smooth as my old shocks. My thinking is that they just need to break in.
Old 01-27-2012, 11:12 AM   #712
burgboyz's Avatar
I run the RSD pistons and bladders in all 12 of my associated shocks and they are smooth as silk. Much better than the stock parts. I use a shock pump to rid the tiny bubbles of course. I also change the red o-ring every time I open them up to re-fill with oil. No issues here. In fact, I cant wait for him to get more bladders in stock!
I hope you get the issue figured out and are able to the RSD stuff! It is a great upgrade!
Got Droop???
Old 01-27-2012, 01:46 PM   #713
Ok I will try then today and at tomorrow races
Old 01-30-2012, 12:33 PM   #714
geeunit1014's Avatar
Good luck to Reflex Drivers Jeff Cuffs and Matt Ward at the Snowbirds! Matt and Jeff are both running 17.5 Blinky TC, and I believe Jeff is running 17.5 boosted TC as well (Matts also running 17.5 pan). I wish I was tearing it up there with them
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 01-31-2012, 12:03 PM   #715
Originally Posted by DARKSIDE View Post
...also when will the bladders be in?
+1
I want to order a few things, but would rather get it all done in one order.
-Mike
Old 01-31-2012, 05:45 PM   #716
Bladders will be about a month or so... With the lunar year holiday everything is shut down for another week or two overseas at the factory where we get our bladders made.
And yes, good luck to all the RSD drivers at the 'birds... Jeff, Matt and whoever else I am missing.
Keven H, will also be representing for RSD, which is so exciting!!! Keven will be testing a few of our items...
Old 02-08-2012, 04:32 PM   #717
DARKSIDE's Avatar
Im going to go ahead and order my other stuff...but I really want those bladders...lets us know as soon as they come in...thanks
ps...Snowbirds was a blast
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 02-08-2012, 05:00 PM   #718
cherokee95's Avatar
I was waiting for bladders too. Guess I'll make a separate order so I can get my 6.1 rolling.
Sioux Falls RC Crawlers
*Futaba*Hitec*Savox*Tekin*Castle Creations*i-Charger*Team Brood*Holmes Hobbies*
~Axial~Tamiya~Locked Up RC~RC4WD~Rogue Element~
cherokee95 is offline   Reply With Quote
Old 02-08-2012, 10:55 PM   #719
Geberit's Avatar
Hello,
just curious how are the DCJs progressing.
PS: the shipping rates were raised drastically for Europe!? 200% or more ...
Geberit is online now   Reply With Quote
Old 02-09-2012, 06:46 AM   #720
I have reflex bladders pm me with your story I can send them out I ordered 6 sets used one lolo
Shortbusallstar is offline   Reply With Quote
