Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)
#379
The Fan Mount should be here soon. Probably inside of 2 weeks. We should also receive some samples of the drive shafts as well.
We have a new Belt tensioner that doubles as a battery spacer so that your batteries don't hit the belt anymore. Samples for those are about 4 weeks out.
Other samples that are in the works are our T6 hardened aluminum Low Profile Ball Studs (to use on the vertical stud mounts and achieve lower inside link locations) which will work especially well on the inside, super long link locations and also on the steering bell crank to help reduce how much the inside turnbuckle hits the bulkhead. We also have "black studs" coming in T6 hardened aluminum.
Finally, recently I found a small production run shop here in Texas that cuts carbon fiber products. We are in the process of designing a dual bell crank steering chassis to be used with the XRay parts and probably a different top deck. We'll test it and see how it goes, if it works well, we will do a small production run of the chassis done on a special order level. Turn around is not long with them so this will be our best bet if it works.
#380
Oh boy! You are hard working!
Now I know what you are doing all week long
#382
#384
Let me know if you need help testing the drive shafts.
#385
Narrower than stock chassis without changing steering geometry unless replacing with another system.
Better/tighter battery retention system (a la Photon alloy parts) that does NOT use tape (velcro strap OK). Exotek style cups (alloy or carbon) w/carbon top strap also OK.
Top deck clearance for battery bullets front or rear.
Be sure to have areas where either stick on weights can be mounted and/or holes through the chassis for screw mount weights.
Don't forget an oval hole under the motor shaft for pinion grub screw access.
#387
I now prefer to use only tape after cutting my own slots. Less weight without the brackets
Otherwise, I basically agree with everything else Buckaroo mentioned. The stock chassis is pretty narrow to begin with but it can always go more.......
If you do a dual-arm setup and turn the servo like I did on mine, you may consider a tray/bracket of some sort to allow use of both servo mounts. Mine is currently held using only a mount next to the belt and servo tape, which holds great, BUT some may want the added "security".
#388
#390
CWoods, since we would be making an all-new chassis, we would definitely have to make it so that you can use 2 servo mounts with the servo turned sideways a-la Tamiya/Yokomo.
Also, while tape works well, it still needs some sort of cradle to hold the batteries in. We'll see what comes of this
