Old 08-31-2011, 06:06 PM   #316
CristianTabush's Avatar
looking good! Let us know how it works out!
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 08-31-2011, 09:21 PM   #317
Jochim_18's Avatar
From my experience dual steering bellcrank is good for MOD cause the steering feel is more precise and not too aggressive while the single steering bellcrank is more direct feel and faster steering response which is good for stock.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 09-01-2011, 08:14 AM   #318
Cristian, ended up with a TC5R in a trade. Think I might keep it and come run with y'all occasionally. I assume the bladders will fit the TC5 shocks?
Who the ^&@$#()! Is Jason Branham!?
cjtamu is offline   Reply With Quote
Old 09-01-2011, 11:06 AM   #319
Yes, the bladders should fit the TC5 shocks.
Sounds awesome about the car.
Old 09-01-2011, 02:01 PM   #320
Default Bladders now in stock!!!
Bladders are now in stock and shipping!
Old 09-02-2011, 07:50 AM   #321
Default 12.5 Lb Springs
12.5lb springs are now in stock and shipping!
Also, the spring sets now include all 5 spring types!
Old 09-02-2011, 09:03 AM   #322
cwoods34's Avatar
ETA on the new drive shafts and/or fan mount? Will be placing another order soon...........
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 09-02-2011, 09:15 AM   #323
JRXS_chris's Avatar
Really impressed with the steering mod on the last page. I'm going to do the same thing to mine.
JRXS_chris is offline   Reply With Quote
Old 09-02-2011, 09:22 AM   #324
Fan Mount is just a couple of weeks away. The drive shafts we have not yet received the prototypes, but we will soon (hopefully ).
Also in the works is a battery spacer/Belt tensioner to prevent the battery from rubbing on the belt and make belt tension adjustment a little bit easier.
Old 09-02-2011, 09:23 AM   #325
Oh, and I see Steve in here... We also have hub offset spacers in 0.5,1.0,1.5 and 2.0mm sizes...
Old 09-02-2011, 10:16 AM   #326
cwoods34's Avatar
I looked at the S411 setup but couldn't easily find all parts I needed. The 416/417 and TCX are nice setups also but both look like they need to be mounted to the top deck to stay together. The XRAY setup comes as a package and is surprisingly the cheapest.
You'll have to drill the holes, and can't use the stock battery mounts. I cut 2 tape slots for the battery.
I do have an idea for a setup that might work as a bolt-on (for dual arm and turned servo) but I'll have to look at the car later and see if it'd work.
Old 09-02-2011, 10:17 AM   #327
wtcc's Avatar
Nice to see the new products! What about the anti roll bar collars? Are these still planned?
wtcc is offline   Reply With Quote
Old 09-02-2011, 10:29 AM   #328
Kevin, the sway bar collars are actually in production as we speak. These will be the next ones to arrive within 3-4 weeks (hopefully less ).
Old 09-02-2011, 05:10 PM   #329
Buckaroo's Avatar
What method is everyone using to build zero rebound shocks? Drilling the cap and leaving the foams out?
Also, product idea: Diff covers like the Photon. Keeps dirt and grit and carpet fuzz out of the diff. Works amazingly well!
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 09-02-2011, 07:01 PM   #330
VAzRACER's Avatar
Trader Rating: 17 (100%+)
A 1mm hole in the top cap worked great for me.it's difficult to get zero rebound but the 1mm hole gets it to around 10% That's as close as I can get them. The TC6 shocks don't have foam like the Tamiyas do. Cristian pointed out that the stiffness of the bladder contributes to not being able to get true zero rebound. the new bladders should fix this.
Reflex Racing / Psycho Cells
VAzRACER is offline   Reply With Quote
