Old 10-30-2014, 10:59 PM   #2806
Trader Rating: 27 (100%+)
Cool, sent you a message
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 11-05-2014, 05:30 AM   #2807
Hi Christian can you please tell me when bulkhead braces will be back in stock? i wish to order now. also have an unanswered question in my member account on your website. id 1554.
jonston is offline   Reply With Quote
Old 11-05-2014, 07:43 AM   #2808
CristianTabush's Avatar
All inquiries should have been responded to.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 11-05-2014, 07:45 AM   #2809
Trader Rating: 61 (98%+)
Hey Christian, any word on the new touring car body?
thecaptain is offline   Reply With Quote
Old 11-05-2014, 07:50 AM   #2810
Nothing to report right now, still a work in progress.
Old 11-05-2014, 07:57 AM   #2811
patorz31's Avatar
Hey Cristian can you do custom Chassis in Carbon for other makes? I loved your stuff for the TC6 but now I am driving a VBC D06 and would like a softer Carbon Chassis that would allow me to use the Spec-R Suspension mounts.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 11-11-2014, 08:10 AM   #2812
Jorge T's Avatar
I just built and tested my RSD7 aluminum chassis last Saturday and was greatly impressed. It drives better than my BD7 2014 with aluminum chassis/short shock or set up w/carbon chassis.(selling it now).
I have the RSD7 set up with the lowered shock towers, stock 6.2 upper deck and it is very consistent lap to lap. With limited setup time I was just as fast as with the yokomo.(The yok was not as consistent lap to lap.)
This week end I will try the bulkhead braces to see how it changes the feel. I am very exited about this car!
RSD MS
Jorge T is offline   Reply With Quote
Old 11-11-2014, 11:02 AM   #2813
I can, however I don't have a chassis or chassis file. If you send me the parts I can try to do so, but the drawing fee is typically the expensive part. If you have access to a solidworks or dxf file, it would not be much more than just a regular carbon chassis.
Old 11-11-2014, 11:11 AM   #2814
Default Bulkhead braces
I have the 6.2 with aluminum chassis do you still recommend the bulkhead braces? or is this more for the carbon chassis
tbamsey is offline   Reply With Quote
Old 11-11-2014, 07:22 PM   #2815
Do you have an eta on the aluminum chassis? Thanks!
Andrew Cartwright
A_Cartwright is offline   Reply With Quote
Old 11-12-2014, 02:56 AM   #2816
Jorge T's Avatar
The braces are an additional tunning part for both carbon and aluminum chassis. They can be used with stock and aftermarket top braces as well.
From Reflexracing: "For example, if you want more on power rear traction, install the rear brace. If you want more on power steering, install the front.
When using both braces, the car will stay a little bit flatter at high speed, will be easier on tires, the response will increase in tight corners and the car will be easier to drive in sweeping corners."
RSD MS
Old 11-12-2014, 10:26 AM   #2817
rc pete's Avatar
In my testing, the Alum chassis flattened out the feel of the car and I was able to soften up the suspension a bit more to pick up some more roll. I did try the braces with the Alum chassis, as well. Definite increase in response, but flatter again. I took them off but will try them on my standard chassis car.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 11-17-2014, 08:28 AM   #2818
CraigH's Avatar
Default Custom chassis
How about doing a aluminum chassis for tc4 drivetrain and tc6.2 suspension? Use low profile shocks, and custom shock towers. Also maybe make some input shafts to use the b44.3 gear diffs.
CraigH is offline   Reply With Quote
Old 11-28-2014, 10:07 PM   #2819
Any updates on the aluminum chassis, specifically the custom one I ordered?
Old 11-30-2014, 11:15 PM   #2820
Cristian,
Have you considered making some retainers for T4'15 swaybars that will fit onto T3/T4 bulkheads? I don't imagine it'd be a problem if the swaybars fit a bit higher. Spacers could be added to the endlinks to compensate.
-Mike
