Old 08-19-2014, 01:20 PM   #2731
CristianTabush's Avatar
Yes, I have. Same improvements are present.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 08-21-2014, 11:11 PM   #2732
Trader Rating: 41 (100%+)
I just got my RSD Aluminum Chassis and High Response Top Deck in the mail yesterday! Can't wait to put it on and see what it's all about!
markpoleon is offline   Reply With Quote
Old 08-22-2014, 05:35 AM   #2733
Christian, whats the approx weight saving from stock with your arm kit? my car is about 60 grams over legal weight at the moment.
jonston is offline   Reply With Quote
Old 08-22-2014, 08:11 AM   #2734
I will give you a number later on tonight. The savings is about 1.5 g per a arm if I remember correctly. Total maybe 8-10g in savings?
Old 08-25-2014, 10:37 AM   #2735
Castradamus's Avatar
Trader Rating: 53 (100%+)
Default TC6.2 DCJ
TC6.2 DCJ
Can someone explain to me the difference between the AE and RSD. Why do you need a different wheel hex for the RSD version.
Destiny | Xenon USA | Speedzone | High Velocity RC | TQ Wire | dIgItS pAiNt
He who is not courageous enough to take risks will accomplish nothing in life. - Muhammad Ali
Castradamus is offline   Reply With Quote
Old 08-25-2014, 10:56 AM   #2736
Our DCJ uses the industry standard axle size. It requires a 2mm hex pin and a slightly different diameter opening on the hex for the larger size axle and pin. Basically, every car in the market except for the AE Car uses this type of hex and pin.
Old 08-25-2014, 12:11 PM   #2737
Would I just need 1 pair of hexes for the front or 2 pair for the whole car?
Old 08-25-2014, 01:59 PM   #2738
Just 1 Pair for the front and some drive pins.
Old 08-25-2014, 03:42 PM   #2739
Trader Rating: 21 (100%+)
How is the 1/12 scale body coming along? interested in trying it out for the coming winter races
Scirocco is offline   Reply With Quote
Old 08-25-2014, 03:43 PM   #2740
Skiddins's Avatar
Hi Cristian, do you have any idea when you'll have some more RSD DCJ's and power banana's in?
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-25-2014, 05:17 PM   #2741
The DCJ's are in stock. With the exception of the wide axle, which we are not sure if we will get back in stock.
Power Bananas have been back ordered for a bit, but I should be getting an order in within 10 days or so.
Old 08-26-2014, 02:40 AM   #2742
Skiddins's Avatar
Any particular reason for not getting the wide axle version in?
I've found the wider axles to be faster at my local tracks (back to back testing)
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 08-26-2014, 08:09 AM   #2743
Not enough demand for them right now. Most people select the narrow axles as they are slightly more efficient and they tend to lastt longer.
If all conditons are even when you do your testing, I would try to make the front slightly stiffer with the narrower axles, maybe by standing up the shocks 1 hole. The narrower axles don't create as much suspension bind so maybe this is what is causing this to be the case for you.
I have personally never noticed a difference in lap times. However the durability is better for the narrow axle.
Old 08-26-2014, 04:25 PM   #2744
Sorry, missed this post. The 12th scale body is almost ready. We are waiting on production samples in order to submit them to ROAR for approval. Once we get the okay, and know if we do not need to make any changes, we will go into production. I hope we can have it ready before IIC.
I am very happy with the performance of it. The body is a little more aggressive than the AMR, but not quite as much as the R8C. It tends to be a little "freer" in the corners and flatter cornering at the front, which gives a little more steering.
For set-up, typically I run a slightly softer center spring with it over the AMR, which helps tame the car a little bit.
Our goal with the body is for it to provide less fade through higher efficiency so that the car can run stronger throughout the run. I feel we achieved this with the body. In 13.5, I am slightly faster on hot lap and about 2-3 seconds faster over the AMR.
Old 08-26-2014, 07:26 PM   #2745
Ok, thats what I'm looking for. I pretty much run the amr all the time, found everything else either too aggressive leading to fade in the end if the run or just way too much steering in 13.5. Thanks
