Old 08-14-2014, 09:50 AM   #2716
ALUMINUM CHASSIS + HIGH RESPONSE TOP DECK = KILLER on carpet!!!..lol...good job REFLEX!!!
Team Integy .. Speedtechrc.com .. Gridworksracing .. .. Tq raceway ..Roudrunner raceway
AE6.1wc and 6.2
Awesomatix
johnsonthai is offline   Reply With Quote
Old 08-14-2014, 09:54 AM   #2717
cmunro's Avatar
i have been running the same combo for a couple months and it is amazing
REFLEX RACING/TRINITY/HOBBYWING/AIRTRONICS
cmunro is offline   Reply With Quote
Old 08-14-2014, 12:52 PM   #2718
CristianTabush's Avatar
Thanks Johnson! That is great news. All my guys that have installed the aluminum chassis have gone 1-2 tenths faster per lap and their cars get much more consistent over a full run.
Now, if you want to take it to another level, the Lightweight suspension makes it even better. These should be ready to ship on Monday and I only have a few sets left.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 08-14-2014, 03:41 PM   #2719
Madulla's Avatar
Thank you Christian for the amazing customer service. Keep up the great work.
Stop tempting with a new chassis haha
Hobbywing North America Team Driver
hobbywingdirect.com
CARCAR VP carcar.ca
Madulla is offline   Reply With Quote
Old 08-15-2014, 10:31 AM   #2720
NP Cristian....always willing to take it to the next level!..lol...you gonna send me some new arms to try..jp...lol.....Keep up the good work...cant wait to see whats next from you guys!!
AE6.1wc and 6.2
Awesomatix
Old 08-15-2014, 10:47 AM   #2721
cmunro's Avatar
i ran the light weight arm set up on my car last night it was dailed ,well worth the cost to get rid of the sloppy stock plastics
Old 08-15-2014, 06:15 PM   #2722
Thunderbunny's Avatar
Trader Rating: 22 (100%+)
+1 Saw the car in action last night!
Chris Jones a.k.a. "Black Jesus"
O.S. l Airtronics l RSD l
Team ARC l Gulf Coast Raceway Porter,Tx
Thunderbunny is offline   Reply With Quote
Old 08-15-2014, 06:42 PM   #2723
Trader Rating: 49 (100%+)
Hey Christian can you post your set up like you did the last one. But this time with the new suspension parts? I would like to use those settings as a base starting point. Please and thank you.
thecaptain is offline   Reply With Quote
Old 08-16-2014, 08:46 AM   #2724
Here we go:
Front:
Upper tower: ooxo oxoo
Lower Arm: C
Piston: 315 (3x1.15)
Oil: yokomo 500 (ae 40)
Spring: yokomo blue (rsd light blue)
Yellow sway bar
Wheelbase: 4mm behind arm
Arm mounts:
FF: ( ..)(.. )
FR: ( ...) (... )
1mm under all suspension mounts
0mm ackerman shims
RSD servo mount
4mm hex with 0.5mm shim
Inside link: 2mm
Outside link: no shims rsd black stud
Rear:
Upper Tower: oxoo ooxo
Lower arm: C
Piston: 315
Oil: 500
Spring: yokomo black (rsd white)
White sway bar
Wheelbase: 4mm in front of arm
Arm Mounts:
FR: (.. ) ( ..)
RR: ( . ) ( . )
1mm under all mounts
1mm inside link short stud (ae black)
2mm outside link (ae silver)
3000cst diff
Std hex
RSD aluminum bones
If it were asphalt, I would just change to an HPI silver/ RSD gold spring. And maybe give it a little more rear toe. Everything else should be pretty close.
Old 08-16-2014, 12:04 PM   #2725
Here we go:
Front:
Lower Arm: C
Yellow sway bar
Arm mounts:
FF: ( ..)(.. )
FR: ( ...) (... )
0mm ackerman shims
RSD servo mount
Inside link: 2mm
Rear:
Upper Tower: oxoo ooxoo
Lower arm: C
Piston: 315
Oil: 500
White sway bar
Arm Mounts:
FR: (.. ) ( ..)
RR: ( . ) ( . )
3000cst diff
Std hex
RSD aluminum bones
I belive there is a typo in your rear shock position for the tower. Also what is considered the a b c holes for the arms? Thanks for the set up!
Old 08-16-2014, 12:22 PM   #2726
The c position is easy to identify on the arms. It is molded in.
The typo is fixed.
Old 08-16-2014, 01:31 PM   #2727
The typo is fixed.
Thank you Christian.
Old 08-16-2014, 08:55 PM   #2728
Trader Rating: 73 (100%+)
Originally Posted by thecaptain View Post
Ya it the suspension parts are the same
However the two cars besides a few other parts are completely different so they'll fit on but besides that is kind of a mystery.
Thanks for your reply!
bullet100 is offline   Reply With Quote
Old 08-16-2014, 08:56 PM   #2729
They will, however the extra shimming will make the arms more prone to making the suspension mounts develop play.
Thanks Cristian, just ordered a set!
Old 08-19-2014, 11:41 AM   #2730
bigl's Avatar
Trader Rating: 25 (100%+)
Cristian havd you tested the new suspension parts on asphalt?
bigl is offline   Reply With Quote
