Old 06-30-2014, 09:27 AM   #2671
CristianTabush's Avatar
That is great news!
We should have the prorotype motor mounts this week. We'll do some testing and evaluate them over the next couple of weeks.
Thanks!
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 06-30-2014, 10:01 AM   #2672
patorz31's Avatar
I would be interested in a Aluminum Chassis for the T4'13 also.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
SCHUMACHER RACING Canada,TEAM POWERS, Mon-Tech,Sanwa
patorz31 is offline   Reply With Quote
Old 06-30-2014, 11:13 AM   #2673
We'll look into it, however I just don't know if we can get enough demand up for them.
In other news, for those of you that pre-ordered the RSD6.2 EVO Chassis, we will have the chassis ready in about 10-15 days. The new version is a Specially made, limited edition just for the guys that pre-ordered it. We will have something like 2 extras, so if anyone wants one, you better jump on it.
The new chassis will be compatible with our RSD7 Keyed battery holder and also has a new, updated chassis shape to promote better roll into the corners and higher corner speed.
Thanks for your patience guys, please know that what you are getting is a custom-just for you guys chassis.
Old 07-07-2014, 06:10 PM   #2674
Bigz84's Avatar
Trader Rating: 20 (100%+)
Default team prime center shock
Cristian, or any other 12th scale driver,
for the Team Prime center shock, which spring should I use for the center shock? I placed the kit one on it, but I bought the spring kit as well. I have put 40wt oil in the shock. it is being mounted in a X12, for 17.5 blinky carpet.
thanks for any info.
Airtronics/Sawna : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : RCAmerica : Hudy : Xray : Diggity Designs : Team Scream Racing
Bigz84 is offline   Reply With Quote
Old 07-08-2014, 01:06 PM   #2675
cmunro's Avatar
Most of the guys locally are using the rsd red spring , Im pretty sure thats what cristian has on his x12
REFLEX RACING/TRINITY/HOBBYWING/AIRTRONICS
cmunro is offline   Reply With Quote
Old 07-08-2014, 04:52 PM   #2676
Bigz84's Avatar
Ok thanks for the info, ill be putting that one on
for reference, what is the team prime spring rated at (the one that comes in the package) compared to the RSDs?
Old 07-08-2014, 05:06 PM   #2677
Thanks Charlie, yes red spring with 30-35 wt AE oil on the center shock.
Old 07-11-2014, 03:02 AM   #2678
Should get a 'limited edition 1/x' engraved on the chassis for the 6.2's
RSD Spec TC6.1, Tekin RS, MMM, Sav÷x, Sorex.
Steve89 is offline   Reply With Quote
Old 07-11-2014, 03:34 PM   #2679
Bigz84's Avatar
OK on the shock oil. will change that out as well.
thanks guys
Old 07-24-2014, 07:22 PM   #2680
ViperZ's Avatar
Cristian, what battery holder is required for the TC6.2 aluminum chassis? RSD7 Keyed battery holder?
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 07-25-2014, 03:31 PM   #2681
Depends on what you are trying to achieve.
If you want to use tape:
-No holder system, just center battery spacer
-RSD7 Keyed battery hold down system (comes with the center spacer)
If you want to use the Tab system, then you need:
-TC6.2 Battery Hold down system
And one of the following
-RSD7 Keyed carbon Fiber Holders (need to use some o-rings/lexan shims on battery to take away some of the side-to side movement, depending on battery pack)
-XRAY Plastic Battery holders (need to shave just a little on the inside to be able to space the battery out slightly.)
-XRAY adjustable Carbon parts (Hold the battery nice, but since they are not keyed, they move a bit.)
Old 07-25-2014, 03:33 PM   #2682
Default Back in stock
We also have more of the RSD7 Aluminum chassis in stock as well as all of our AE specific pistons.
On another noted, for you 12th Scalers, we now have a transverse battery layout for the RC12R5. This should be available early next week.
Old 07-26-2014, 05:39 AM   #2683
ViperZ's Avatar
Thanks, got it! I was not sure what was required when I was looking at the information on your site. The tape seems like the simplest option.
Old 07-28-2014, 11:19 AM   #2684
wtcc's Avatar
Dear Christian,
can you give me an update on my order. Our last conversation concluded in you telling me, that you wanted to send it out again (after the customs returned it).
If possible, can you give me the tracking number?
Thanks!
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 08-02-2014, 04:32 AM   #2685
Any word on these??
