Old 06-10-2014, 03:07 PM   #2656
CristianTabush's Avatar
Originally Posted by Carnage9270 View Post
I'm very interested in what you are doing with the RSD7 Cristian. Curious on what your opinions are on the ARS system people are playing with?
It's just another optional part. I don't think it will be better, but it gives certain advantages over the regular set-up at the expense of durability and "precision".
It might be the wave of the future, but who knows, what is old is new is old... We use to have this on the old Schumachers and we hated it because when you tapped, the toe would be off. I do see where there can be a benefit though, but I think with the 6.2, it's in the arm length when you fit front arms in the rear that I believe is making the biggest difference.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 06-10-2014, 03:56 PM   #2657
YoDog's Avatar
Trader Rating: 25 (100%+)
Originally Posted by CristianTabush View Post
We already sell an optional set of retainers and a central battery stop as well. It is an option part though, and it is not included in the kit.
Ahhhh... I see.
Sorry
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 06-10-2014, 04:54 PM   #2658
No worries, thanks for the offer.
Old 06-15-2014, 11:38 PM   #2659
We worked on a good base set-up for the aluminum chassis for carpet this past Saturday. The car felt really, really good.
Here it goes:
Front:
3x1.1 Piston 40wt
Black Yokomo Spring/ RSD white
Short Camber links
B Hole Lower Arm
OOXO OXOO Upper Tower
2mm under inside link
1mm under outside link (silver stud)
1mm Ackerman Shim
Front Wheelbase all the way short
1mm Roll Center Shims under all front suspension Mounts
( . ) ( . ) FF
( ..) (.. ) FR
2 Deg Camber
Yellow Swaybar
2-2.5mm droop over ride height
Rear:
3x1.1 Piston 40wt
Short Camber links
B Hole Lower Arm
1mm under inside link
2mm under outside link (silver stud)
Rear Wheelbase 1mm in front of rear arms
( ..) (.. ) RF
( ..) (.. ) RR
2 Deg Camber
Yellow Swaybar
Rear Diff 3000cst oil
Spool Front
Diffs Mid low F/R
Battery Plugs back
Body: MS6/ Montech Nazda 2
Old 06-16-2014, 10:52 AM   #2660
RussF's Avatar
Trader Rating: 21 (100%+)
Can someone help me with the parts selection to make for parts to rebuild my V2 Narrow DCJ's for my TC6.1? I lost a small pin and retaining ring last race and need to order some replacements. I see the rings but no pins to order. Part # RSD070-1 says pins in the description but does not show them in the pic. Help please.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 06-16-2014, 11:02 AM   #2661
erchn's Avatar
I think this is what you need.
http://www.reflexracing.net/RSD-DCJ-...cs_p_1124.html
E
RCAmerica ; Team Powers USA ; Reflex Racing ; RC≥ RC Crew Chief ; Bezerk RC
erchn is online now   Reply With Quote
Old 06-16-2014, 11:34 AM   #2662
RussF's Avatar
I think those are for just the hex hubs as the pins for the DCJ's are two sizes. One longer, one shorter. The parts I am looking for are in this picture https://reflexracing.3dcartstores.co...J_Exploded.jpg. They are left side ring and pin part. I'll be darned if I can find them on the part list on their site.
Old 06-16-2014, 11:37 AM   #2663
erchn's Avatar
My mistake. I see rsd021-1, but that looks like for a previous rev of the dcj. I'm sure Cristian can clear this up.
Old 06-16-2014, 01:39 PM   #2664
Trader Rating: 20 (100%+)
Did I hear a rumor that you are going to product a run of aluminum chassis for the RX4 v1?
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 06-16-2014, 05:01 PM   #2665
Troy, we probably won't do an RX4, but we are working on a t4 '14 version. If you want an RX4 aluminum chassis, I can see what it would cost to do 1 off of the '14 files with a slight mod.
Old 06-16-2014, 07:41 PM   #2666
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Send me your address and I'll send you the pin and clips you need. No cost.
Old 06-17-2014, 05:40 PM   #2667
Bigz84's Avatar
Trader Rating: 15 (100%+)
Christian, I might be interested in having one of these aluminum plates as well for the '13. Let me know the cost as well.
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Old 06-17-2014, 06:14 PM   #2668
I will find out soon and let you guys know.
Old 06-23-2014, 06:39 PM   #2669
Default chassis
Just did my first order with you got the aluminum tc6.2 chassis and a couple of other upgrades. cant wait to get them put on the car and tuned Thanks again
tbamsey is offline   Reply With Quote
Old 06-30-2014, 10:14 AM   #2670
Default new chassis
first run on chassis turned out real good gained a lap. It felt a lot more aggressive on asphalt compared to stock one. seemed to carry more speed mid corner and exit
SEO by vBSEO 3.5.0
