Old 06-06-2014, 07:46 PM   #2611
Christian, with the bones. they just lower your rotational mass?
how is wear on them?
jonston is offline   Reply With Quote
Old 06-06-2014, 08:01 PM   #2612
CristianTabush's Avatar
Yes, lower rotational mass and also gets your car lower to min weight when you are shaving weight with an Aluminum chassis.
The wear is pretty good so long as you clean them and grease them every couple of track days. The rear bones undergo very little stress and angles so they last a long time.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 06-06-2014, 08:41 PM   #2613
The Evicerator
Looking good!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 06-06-2014, 09:09 PM   #2614
Steve, i finally have some goodies otw to you...
Old 06-07-2014, 06:05 AM   #2615
mutley001's Avatar
Default Rsd 20mm spring kits
Hi all,
I've just purchased 2sets of the carpet and asphalt springs and would like to know a good starting point for carpet and asphalt tracks for my xray t4'14.
Carpet track is high grip tight and twisty running sores 28JB rubber and the outdoor track is low grip, and flows well with a couple of low speed technical sections
Thanks in advance
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 06-07-2014, 06:35 AM   #2616
Skiddins's Avatar
Originally Posted by mutley001 View Post
Hi all,
Thanks in advance
Carpet: Pink, Blue
Asphalt: SilverF, Pink or Blue Rear
Are we talking about Eastbourne?
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 06-07-2014, 06:49 AM   #2617
mutley001's Avatar
Originally Posted by Skiddins View Post
Carpet: Pink, Blue
Good guess! I don't get down there very often but like the track. Would you recommend the same for west London? I hope to make it over there soon.
ARC R11 2017
ARC R10 2013
Team EAM
Old 06-07-2014, 08:10 AM   #2618
The Evicerator
Sounds great Christian, very much looking forward to it!
Steve Weiss
Old 06-09-2014, 07:26 PM   #2619
Trader Rating: 47 (100%+)
So Christian switching my car over to the new aluminum chassis. Get the battery section HOLY CRAP. How do you FORGET TO MENTION that you need to purchase the rsd battery holds and battery stop! There is legitimately 3/16 of an inch if not 1/4 of an inch of play inbetween the stock battery holders... you cant even put two screws in the battery holders because theres not room because the chassis is so narrow. Then I finally get the battery in the car. I use a buggy foam spacer and some two way tape to make it fit properly. REALLY JANKY but it works, fine no biggy what ever ill send christian a private message about it. But I look at the battery stop now and its not close to that either theres a good 1/8 of play between the battery and the battery stop, free to slam into the belt as it likes. So now not only do I get the privelage to fix more of your products. I have to spent more of my time to do so... brilliant please explain to me why this was not mention in the chassis description. Or on any forum. I am looking forward to the reason. Its a marketing ploy, I get it. You want people to buy your other products. Generally those companies mention that their parts are the ones that work with the new what ever they release... HIGHLY UNSATISFIED...
thecaptain is offline   Reply With Quote
Old 06-09-2014, 07:35 PM   #2620
The chassis is meant to be used with tape, much like the Yokomo and all of our previous chassis versions. There is no need for battery holders on a chassis like this. It is an option, but not necessary.
Making the stock battery holders work is not an option, as the shape of the chassis necessitates a different bolt pattern.
I am sorry for the confusion, it is not something we do intentionally. However, I can tell you that using just tape you will be fine.
Old 06-09-2014, 07:41 PM   #2621
To add, personally I don't use a holder on the Aluminum version because it adds unwanted weight to an already heavier car. If I use the CF version, I do use them for extra safety, but they really are just something that some people may want or may not want to use on their car. That's why we sell it as an option part and don't advertise it as a "Necessity".
Old 06-09-2014, 07:43 PM   #2622
that only addresses part of a problem viewed as a matter of opinion... what about the battery stop...
Old 06-09-2014, 07:47 PM   #2623
You should be able to use the standard battery stop at the inside without any issue. Are you having fitment issues?
Old 06-09-2014, 07:48 PM   #2624
You can keep the battery stop on there if you want, but what I think Cristian is trying to say is, if you use tape and put it through the cutout areas, your battery wont budge and there's no real reason to have a battery stop.
Edit: Sorry Cristian...ewe got dis
-Mike B.
Carnage9270 is offline   Reply With Quote
Old 06-09-2014, 07:50 PM   #2625
Correct^^^ Thanks for verbalizing in a different manner.
Basically, at the center, the stock TC6 battery stop should keep the battery from hitting the belt, much like on the original car.
At the Fore-and-aft positions, so long as you file your tape slots (You should always chamfer tape slots regardless of stops or battery cradles when using tape) you should not need any other parts to use the chassis. Tape is more than sufficient to hold your battery securely even at the highest modified speeds. All the other items are optional.
