Old 03-04-2014, 03:36 AM   #2551
JimmyMac's Avatar
Originally Posted by Bar View Post
hey Cristian, do you know when your new yokomo bd7 adjustable battery retainers will be ready ?
+1
I've been holding off buying a different set.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 03-04-2014, 07:27 AM   #2552
CristianTabush's Avatar
Unortunately, i don't have a date. There has been a delay because I am shopping around the product with a few new vendors in order to get the price down a bit. Otherwise, we'd have to sell for around $50.00 per set.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 03-04-2014, 08:10 AM   #2553
Trader Rating: 22 (100%+)
my rsd spool cups came in yesterday along with ae's new dcj kit, the dogbone would barely go into the spool cup. I ended up sanding the dogbone's until they had free movement. Not sure if this was an intentional change by ae or not my old cva's fit properly.
noproblems209 is offline   Reply With Quote
Old 04-25-2014, 05:44 AM   #2554
Is there ever going to be any more production on TC6.1 chassis parts? I'd love to get a hold of either an evo1 or evo2 chassis, I wore out my evo1 racing outdoor
RSD Spec TC6.1, Tekin RS, MMM, Sav÷x, Sorex.
Steve89 is offline   Reply With Quote
Old 04-25-2014, 08:51 AM   #2555
This is a good question. I will look into it to see what we can do. If I can get a commitment of say 5-8 chassis kits, we can get a small batch of them made.
If anyone is reading this that is interested in one, let me know on the forum and we can issue another small batch and start maybe a "pre-order" on the website. Same with the lowered shock towers.
Old 04-25-2014, 08:59 AM   #2556
I would be interested cristian. I'm currently running my TC6 in VTA but might end up getting a TC4 for VTA. Then getting a conversion for my TC6. You still have the original RSD6 conversion in stock whats the difference between that and RSD6.2 EVO?
Never give up!
Traxxas Slash 2wd, Spektrum DX4c, Associated B5m
Wil Holmes is offline   Reply With Quote
Old 04-25-2014, 09:05 AM   #2557
The difference is the chassis shape and battery mounting. I think with what we have learned, we'd make a 2.5 version for limited release. I would make it a mix of the 2.
Old 04-26-2014, 08:02 PM   #2558
mikel33's Avatar
Trader Rating: 2 (75%+)
Would anyone have a starting set up for asphalt mod for the RX4?
Michael Larson.
Village Idiot Racing
mikel33 is offline   Reply With Quote
Old 04-26-2014, 09:28 PM   #2559
Trader Rating: 20 (100%+)
I do not but my plan is to just drop my car down with the carpet setup for the RX4 and tune from there. I suspect it will need some steering if you are going to run at Leisure Hours compared to a carpet setup.
Did you run an RX4 at the VTA race at Harbor this month?
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 04-26-2014, 10:58 PM   #2560
mikel33's Avatar
No, I ran my std T4 in 17.5. I did run the RX4 as a usgt car in Ft Wayne at the vta/usgt race there. It was pretty good. I made the show but I didn't have time to completely dial the car in so I was pretty much back half of the main.
LH will be the primary place I run mod. we run 13.5 at our place. thx. for the tip, I'll work on that for the 1st points race at LH.
Michael Larson.
Old 04-26-2014, 11:56 PM   #2561
I would start with the following:
4x1.1 or 3x1.3 pistons
AE 35WT Oil F/R
Short links F/R
RSD Silver springs all around
Front pins
(.. )( ..) FF
(... )( ...) FR
1mm under all the mounts
Rear Pins
( .) (. ) RF
( .) (. ) RR
1mm under all pins
Wheelbase 1mm short in the rear
2k Rear Diff
Spool Front
1mm under rear inside links
2mm under front inside links
1mm outside front links
4/3mm Outsider rear links
4 Deg Caster
Shock towers:
Front
(oXoo) (ooxo)
Rear
(ooxo) (oxoo)
Ride height 5.5R 5.0F
Droop 3mm over ride height R
2.5mm Front
That should get you in the ball park. I would tune with springs (XRAY 2.7 f/r are pretty good 2.3-2.6 are good for a bit more rear roll/ rotation)
Old 04-28-2014, 04:24 PM   #2562
mikel33's Avatar
Originally Posted by CristianTabush View Post
I would start with the following:....
Thanks!
Michael Larson.
Old 04-29-2014, 02:02 AM   #2563
Cristian,
Put me down for a TC6 rerun for sure. I'd be keen to get a spare chassis as well as I run a lot of outdoor on bumpy tracks.
Cheers.
Old 05-01-2014, 10:46 AM   #2564
Default This is a GREAT PRODUCT!!!!!!
I converted my two T4 Xray cars to the RSD conversion and drove them at The Grand Finally race at The Gate. The cars were DIALED!!!!!!! They were the best handling, most consistant cars I have ever put on a track. It only took a few adjustments and I had a GREAT weekend of racing. If you are thinking about the RDS conversion for your car, DO IT!!!!!!!
TWILL is offline   Reply With Quote
Old 05-01-2014, 01:47 PM   #2565
That is awesome to hear! We love nothing more than to hear our customers enjoying their cars.
