Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)
#2537
#2538
Disregard
#2539
Can you please, please, please, test the latest Xray short springs and add them to your chart along with your latest springs.
Skiddins
Skiddins
#2541
New Items In Stock
RSD123 RSD Silicone Gear Diff Putty
This stuff is for when 2.5 Million is still not enough. It provides maximum steering. The silicone putty makes your diff feel like a spool that simply has more turn in. Not much On Power Steering is lost.
RSD124 RSD Black Grease
RSD125 RSD Pure Silicone Diff Grease
Pure Silicone Grease which is excellent for your Pan Car/ F1 Ball diff.
RSD126 RSD Drive Joint Grease
Excellent anti wear grease for drive shafts and drive pins.
RSD127 RSD Black Silicone Wire Pigtails
Soft, flexible wire to black out your electronics.
RSD1212 RSD 12th Scale Front Roll Center and Ride Height Shims for CRC (0.5 and 1.0mm)
This is a Roll Center and Ride Height Shim Kit for your 12th Scale. Designed to be used mostly with the CRC Front end, the hole spacing will still work as a ride height Shim for and old school front end and any of the old standard screw pattern ones as well.
The shims are 0.5 and 1.0 mm and they are made from black G10. These shims can alsocbe used to fine tune the front roll center of your CRC Front end car.
#2542
Hey Cristian, any idea when the battery hold RSD battery hold down for the T4 will be back in stock? I had a guy t-bone me really hard and I broke one of the posts.
#2544
Here's a video of the putty:
http://www.youtube.com/watch?v=e_8dzIUcv8I
I was able to improve the hot lap by a tenth over the 2.5 million diff today nearly matching the fastest lap I have ever done on the layout we have right now (8.920 vs 8.965). Mind you there has only ever been three 8.9 second laps on our layout ever.
The set-up needs a little bit of refinement as the car is just not as consistent as with a spool or a 2.5 million diff. However the car carries visually more speed and is much better in the 2 sweepers on the track. I REALLY like this stuff. A few tweaks on the set-up and I might be making the permanent switch to the gear diff (I usually prefer the spool as it is about a tenth quicker.)
#2546
Possibly the worst customer service
I haven't been in this hobby very long and just only got into TC in the last 6 months and I'm enjoying it extremely. You guys are putting out some really outstanding parts for my 6.1 and 6.2 but your customer service is possible the worst I have ever dealt with, in and out of RC. I have submitted multiple messages on your website (no one ever picks up the phone) and have not received any response in weeks. Like I said in one of the messages, I place more value in the way a company treats it's costumers that the products they put out. Which is a shame again since you guys have a lot of good parts coming out.
#2547
sorry it seems like you are having an issue with getting a hold of somebody....but I will say in RSD defense...Ive been ordering stuff from them for a long time and if any issue was ever brought up, it was taking care of quickly and with an explanation...
I would just email CT ....I just rec a email earlier today...if like fwd your complaint and Ill send it myself
[email protected]
hope it gets better
Myron
[email protected]
hope it gets better
Myron
#2548
It is hard to handle a complaint on a forum without a name or order number attached to a handle.
Contact me directly at: [email protected] and I will look into this issue further for you.
#2550
hey Cristian, do you know when your new yokomo bd7 adjustable battery retainers will be ready ?
