Old 10-12-2013, 07:56 AM   #2386
Skiddins's Avatar
Hi Cristian
Question on the RX4 conversion
What shims do I have to put under the blocks to achieve the exact same roll centres as T4 kit?
Are your 'recommended' positions on the sheet giving the kit track width?
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-12-2013, 08:32 AM   #2387
Trader Rating: 24 (100%+)
Christian are the 16.0 t4 springs available yet.thanks
Rob Gleason
sponsors: NemoracingUSA, Agama A215,Agama A215e, Beta tires
triplejracer is offline   Reply With Quote
Old 10-12-2013, 09:09 AM   #2388
CristianTabush's Avatar
While I don't have an exact measurement, it should be around 0.75mm of spacing for the roll centers. On the track width:
(. )___________( .) ff and fr
( .)___________(. ) rf and rr
Should get you close.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is online now   Reply With Quote
Old 10-12-2013, 09:11 AM   #2389
Yes, the springs are available and shipping.
Old 10-12-2013, 09:49 AM   #2390
erchn's Avatar
Originally Posted by Skiddins View Post
Hi Cristian
See this post for details on track width and toe.
On the roll centers, the rx4 pins when used with no shims are the same height (measured side by side) as the stock T4 with the -.75 arm holders. So adding .75mm will get you the kit settings. That said, the car *will* roll more than the stock t4, so going to 1mm is a good suggestion.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 10-13-2013, 11:36 AM   #2391
AL1983's Avatar
Hi,
Any one knows were I can get a RSD RX4 Xray T4 conversion in europe?
thx,
(want to avoid custom charges & high shipping costs)
AL1983 is offline   Reply With Quote
Old 10-13-2013, 03:51 PM   #2392
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Shameless plug for anyone looking for a conversion kit
Xray T4 RSD RX4 conversion kit
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 10-13-2013, 03:58 PM   #2393
cwoods34's Avatar
I ran the RX4 chassis on my T4 (plate only) at the IIC and loved it. Qualified 6th in the stock A-main but a sweeper tumble ended me at 9th. The car had loads of steering all week and was still incredibly responsive to small setup changes.
Highly recommended
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 10-15-2013, 04:58 PM   #2394
JayL's Avatar
any idea if the RSD T4 Asphalt springs will work on the VBC D06? or will they be too tall?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 10-15-2013, 07:57 PM   #2395
ngo8's Avatar
Send a message via ICQ to ngo8
Does anyone at RSD know if they answer there emails from there site? i send one about a week ago and i have no reply yet .....missing a package from 4 weeks ago just want to know what happened .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 10-15-2013, 11:45 PM   #2396
Please email directly at: contact@reflexracing.net
We did have communication from a package going to Canada that is missing. Don't know if that may be it. Please email details.
Old 10-16-2013, 12:59 AM   #2397
ngo8's Avatar
OK no problem email sent.
Old 10-17-2013, 09:42 PM   #2398
kuruption's Avatar
Send a message via AIM to kuruption
Originally Posted by erchn View Post
The RX4 kit should have come with initial recommendations. The sheet that came with mine said front inserts should be single dot outside ff and fr, and 2 dot inside for rf and rr. My measurements show the recommendations sheet being pretty dead on with stock T4 in the front, and more toe in the rear ~.5 degrees.
That said, here's a sheet I made up that represents what I have seen and measured, I've not measured 100% of the positions, but it should extrapolate well. I am running the stock XRAY settings as indicated on the sheet, available here. Note, slight variations in tightening down the blocks can cause a bit of skew, so use these as a reference, YMMV.
Ethan
So based on that chart, using the "stock" settings you have highlighted... are you running 1.5mm narrower in the rear compared to the standard T4 settings or is that 1.5mm narrower compared to using 1-out front and rear? If the latter, how does that track width of -1.5mm compare against the stock T4 track width?
Like you, 2 dot outside RF and RR results in about 3.5* of toe... and I thought about doing 2 RF / 3 RR to get down to 3* but seeing your chart makes me wonder if I should go w/ that 1.5mm narrower setup and put on the +0.75mm hubs?
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 10-18-2013, 05:15 AM   #2399
drsfly's Avatar
Default method for removal?
I would like to hear ideas about how to remove the plastic inserts from the aluminum--- without damaging either.
If you needed to adjust toe or width and needed to change one insert for another--- how do you get thhem out?
I tried several different toools--- small sockets, a piece of wood and almost damaged one with a large hex wrench and tapping lightly on it.
they really don't seem to want to come out in the same form they went in.
thx,
Darrald
Do One Brave Thing Today And Then Run Like Hell!
Darrald Spencer
drsfly is offline   Reply With Quote
Old 10-18-2013, 05:20 AM   #2400
I use a small flat head and pry in between the aluminum and plastic lightly. You can also push through with them installed on the chassis with a big tip wrench like a 5mm. However, the flathead screw driver works best for me.
